Dabar yra 22 Bal 2026, 22:50
Naujos temos kūrimas Atsakyti į temą  [ 744 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 29, 30, 31, 32, 33, 34, 35 ... 50  Kitas
StandartinėParašytas: 18 Lap 2014, 16:15
DmK, paklausk, jis visa lekcijatau atskaitys, kad zvakes dirba visada, net ir vasara kol variklis nepasyla iki +40*C (geriau sudega misinys ir lygiau motoras dirba, greiciau pasyla motoras-maziau visokio sh...per ziedus i karteri patenka (tepala papuola)....ir t.t.
StandartinėParašytas: 18 Lap 2014, 16:17
'06 E65 745D M67 242kW
kiesha rašė:
Ok įtikinai, jau užsisakiau visas 6 Beru :D
StandartinėParašytas: 18 Lap 2014, 17:47
kiesha rašė:
... jis visa lekcijatau atskaitys, kad zvakes dirba visada, net ir vasara kol variklis nepasyla iki +40*C
http://tis.bmwcats.com/doc1053835/
is wds http://www.bmw-planet.com/diagrams/release/en/ :
Preheating System DDE 4.0
The voltage for the preheater plugs is supplied via the preheater relay. The relay is switched by the DDE control unit.
The heater plugs are designed as sheathed-element glow plugs.
Preheater time control
The preheating duration is dependent on the engine coolant temperature and battery voltage and is indicated by the preheating/DDE indicator.
Preheating
At temperatures below 5 °C, preheating takes place for at least 4 seconds. The preheating time increases as the temperature decreases.
After-heating
After-heating takes place after engine start at temperatures below 20 °C in order to improve idle and exhaust characteristics.
Start preheating
Start preheating takes place for approx. 10 seconds if after the preheating time has elapsed the engine is not started and the ignition remain on.
ir gana, jau nugrybauta nuo temos.
StandartinėParašytas: 19 Lap 2014, 15:19
E36 coupe, e39d
E39 m57 2003 m. meta tokia klaida: 261 atmospheric pressure sensor (integrated in ECU) ,nelabai randu paaiskinimu kur ir ka keisti. Dėkui.
StandartinėParašytas: 19 Lap 2014, 15:27
E90 318d M47TU2 BiTurbo
ex E46 320d M47
ex E34 535i M30
ex E46 318i M43
SimaoBMW rašė:
atmosferos slegio daviklis (integruotas i ECU)
StandartinėParašytas: 19 Lap 2014, 20:15
E36 coupe, e39d
_Darius_ rašė:
tiek tai suprantu, bet ar jis keiciasi tik su visu ecu ar galima atskirai pakeisti? kokie simptomai buna neveikiancio?
StandartinėParašytas: 05 Gru 2014, 22:06
Plunge
E36 318TDS compact m41 95m.
E39 525tds m51 97m.
ex. E34 520i m20b20 89m.
ex. E30 324td m21 88m.
gal kas galetumete padeti su klaidomis, gedimas toks kad vaziuojant daugiau negu 80km/h atsitinka kad nebedirba 2 cilindras, uzgesini ir vel uzsivedes vaziuoja gerai kol vel pasieki greiti virs 80km/h tada vel pradeda burbuliuti nebedirba 2 cilindras, jei vaziuoji iki 80 km/h beveik nebuna sito gedimo.
klaida bmwa.jpg [ 115.16 KiB | Peržiūrėta 12462 kartus(ų) ]
klaida bmwč.jpg [ 119.3 KiB | Peržiūrėta 12462 kartus(ų) ]
StandartinėParašytas: 08 Gru 2014, 16:45
BMW 320d E46 110kw
Pas mane sita klaida meta(1A0E, ”Alternator load signal) gal kas zino kame beda? Generatorius krauna gr, 14.2V net kita pakeiciau, bet vis tiek ta pati beda liko
StandartinėParašytas: 12 Gru 2014, 15:27
BMW E60 530D, 2003
Pasitikrinau savo E60 530D 2003m. paramentrus per INPA, ir nelabai suprantu kas yra tas PWG Poti 1 ir PWG Poti 2. Panasu kad PWG Poti 1 parametras ant minimalios normos - ka tai reiskia?
Nuotrauka rasite cia: https://www.dropbox.com/s/3lht3ozvif0ehe0/INPA.png?dl=0
StandartinėParašytas: 12 Gru 2014, 16:20
akceleratoriaus pedalo potenciometrai.
StandartinėParašytas: 12 Gru 2014, 17:53
BMW E60 530D, 2003
O tie parametrai kurie yra rodomi yra blogi? Jei taip, tai ar valomi tie potenciometrai ar tiesiog reikia juos pakeisti?
StandartinėParašytas: 12 Gru 2014, 22:20
Klaipėda - Bergen
Ex... E39 528I
Ex... E39 525I
Ex....E39 530IA
E39 530D 225Ag 490NM
Skype
Nikas
TadasTT rašė:
Paspausi pedala ir pasikeis reiksme, db rodo kokioj padety pedalas, taigi potenciometras (elektrinis rezistorius).
StandartinėParašytas: 16 Gru 2014, 09:49
E60 525d
Egzistuoja inpos versija, su kuria butu galima prie cic prisijungt? Ncs mato kad yra cic ir ji koduoja be vargo bet inpoj tera mask arba ccc...
StandartinėParašytas: 16 Gru 2014, 14:10
donce258 rašė:
Redaguok E60.ENG failiuka (irasyk CIC ar CICE90) galkas ir gausis, SGDAT papkeje CIC.ipo ir CICE90.ipo turi buti
e60.jpg [ 97.29 KiB | Peržiūrėta 12167 kartus(ų) ]
Kazkas gausis panasiai, ir turetu uzkrauti CIC.ipo ar CICE90.ipo, diagnostikai uztektu
cic.jpg [ 79.84 KiB | Peržiūrėta 12167 kartus(ų) ]
StandartinėParašytas: 16 Gru 2014, 14:16
E60 525d
ačiū!
