Dabar yra 14 Sau 2026, 04:26
StandartinėParašytas: 28 Lie 2006, 17:58
ex: E39
ex: E46
now: E87
Gal kas esat isideje http://www.zeckhausen.com/CDV.htm#Figure%205
Tik BMW
StandartinėParašytas: 31 Lie 2006, 08:18
E46 318d
Papildomas kruvis sankabos cilindriukui, daugiau nieko :) Nu, nebent, su savo BMW kazka mokinsi vazineti, tada, kad neistampytu transmisijos ir vaziuokles, gal ir vertetu isideti :)
StandartinėParašytas: 10 Geg 2007, 13:18
ex: E39
ex: E46
now: E87
Kadangi pats uzvedziau sia tema ir taip isejo , kad tik dabar viska issiaiskinau iki galo, pratesiu:
Jai kam idomu
Pasirodo tas CDV stovi daugelyje BMW.
Nusprendziau savo E39 truputi pakastruoti ir isimti sita nereikalinga dali. Rezultatas akivaizdus, is pirmos i antra jungiasi be jokiu sutrukciojimu, jokiu sankabos vedimu, zodziu masina tapo visiskai kita (i geraja puse). Darbas tikrai nesudetingas man darbas uztruko apie valanda su visais sankabos nuorinimais.
Placiau galima pasiskaityti cia: http://www.bmw325i.net/cdv_removal.shtml
Tik BMW
StandartinėParašytas: 10 Geg 2007, 14:18
ex: E39
ex: E46
now: E87
Jo buvimo prasme yra ta, kad jis stabdo sankabos atleidima, ko pasekoje, jei nori staigiau sumetyt begius gausi troleibuso efektas. cia angliskai placiau:
The Clutch Delay Valve (CDV) is a one-way restrictor installed by the factory between the clutch slave cylinder and clutch master cylinder, as shown in Figure 1. It "delays" the engagement of the clutch, much like old record players used a damped tone-arm to gently lower the needle onto the surface of a record.
Because of this valve, no matter how quickly you lift your foot off the clutch pedal, the clutch engages the flywheel at a constant (slow) rate. In theory, it can save the driveline from shock, were an inexperienced (or immature) driver to dump the clutch at high RPM. But in practice, all it does is prematurely wear out the clutch and turn experienced drivers into people who, despite 20 years of practice, cannot shift gears smoothly. During parallel parking maneuvers, the delay can be infuriating, causing constant clutch slippage. And during hard acceleration, the large amount of clutch slippage can greatly shorten the life of your clutch. During normal, sedate driving, the shift from first into second gear is often jerky, leading passengers to question your skill. As the driver, you can see your passengers' heads bobbing back and forth during every shift! Yes, in their minds, they are laughing at you.
Tik BMW
StandartinėParašytas: 10 Geg 2007, 15:05
Chrysler Voyager 2,5CRD 01'
Edvazas
Edvazas
kaip suprasti troleibuso efektas
Ex BMW E39 525tds 97'
Ex Rover 620 SDi 95'
Ex BMW E34 525i M20 88'
StandartinėParašytas: 10 Geg 2007, 15:52
ex: E39
ex: E46
now: E87
BUTENT, kad sankabos deginimas. Ir kokio velnio ji ten kisti. [to Edvazas] O troleibuso efektas, nezinau kaip kitaip pavadint (sankabos vedimas gal), vienu zodziu pabandyk issiimt - suprasi:)
Tik BMW
StandartinėParašytas: 11 Geg 2007, 21:55
Black rašė:
Butent jo isemimas yra tolygus BMW kastravimui ir komfortabilaus automobilio perdarymas i "ALE SPORTINI KULOKA".
Vat kai sudrosite dvieju masiu smagrati, ir kai del susibangavusio sankabos disko prades vibruoti masina, nesaukit garsiai kad tai BMW liga, kad brangus islaikymas
StandartinėParašytas: 02 Sau 2008, 12:46
EX: E39 520 M52 96';
E34 520 M50 90'
kai pirma karta atsisedau vaziuot tai galvojau sankabai amen, net issigandes buvau, bet po to prisiminiau, kad toks daigtas yra, siaip jis nieko blogo, netrukdo isvis, tik kai daugiau uzkeli apsukas ir staugiau jungi begi, tai nebuna trenkimo, o svelniai prileidzia sankaba :)
StandartinėParašytas: 02 Sau 2008, 16:36
bet jis čia tik i naujesnius ejo kiek supratau? :oops:
StandartinėParašytas: 04 Sau 2008, 20:23
E91 325xi N53B30
ex.E46 330d M57N
ex. E46 328i M52TUB28
O pas mane jo visai nebuvo...
ačiū
StandartinėParašytas: 10 Sau 2008, 10:36
E91 325xi N53B30
ex.E46 330d M57N
Jei kas sugalvosite issiimti CDV, stai prasom info su foto (zr. faila), kaip tai padaryti saugiai namu salygomis.
BMW sankabos uzlaikymo voztuvo (CDV) nuemimas.doc [983 KiB]
Atsisiųsta 824 kartus(ų)
ačiū
StandartinėParašytas: 10 Sau 2008, 11:15
E39 530d M57 03'
o kokiose auto toks daigtas gali but? pas mane E36 tds 95m,ar gai but? kazkaip to troleibuso efekto kaip ir nera.
StandartinėParašytas: 11 Sau 2008, 10:29
E91 325xi N53B30
ex.E46 330d M57N
Pasiziurek foto kaip atrodo masina su CDV, palysk po savo masina ir pamatysi yra, ar ne. :idea:
ačiū
StandartinėParašytas: 11 Sau 2008, 20:18
JEEP, e23, e93 lci
Tikiuosi y E36 tokiu nedejo? #-o
StandartinėParašytas: 16 Bir 2008, 18:59
Klaipėda - Bergen
Ex... E39 528I
Ex... E39 525I
Ex....E39 530IA
E39 530D 225Ag 490NM
Skype
Nikas
zillwa rašė:
o kam tau gilintis, pas tave kiek suprantu dyzelis, nedraguoji su ta masina 8)
