Dabar yra 22 Bal 2026, 06:43
Naujos temos kūrimas Atsakyti į temą  [ 133 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3, 4, 5, 6 ... 9  Kitas
StandartinėParašytas: 01 Kov 2009, 19:08
kaunas
E39 01m.4.4
ex-e34 525 tds 94m.
ex-e34 525 shadowline 92m.
neveikia linkas
bmw.noreciau ju tureti daug.
StandartinėParašytas: 01 Kov 2009, 19:14
Viskas veikia. Dar karta patikrinau, viskas ok.
StandartinėParašytas: 02 Kov 2009, 10:09
TT E39 525 98'
andriuska rašė:
.... zalios lemputes gesta laabai letai,viena zalia apie 4000km dega.
Gal imanoma nustatyti jog zalios lemputes degtu trumpiau :?:
Turtingas ne tada kai gali nusipirkti prabangų automobilį, turtingas tada kai gali prabangų automobilį "drožti"...
StandartinėParašytas: 02 Kov 2009, 12:10
imanoma, tik ne su laidu :}
StandartinėParašytas: 02 Kov 2009, 12:16
E39 523i 98`
M52B25, Steptronic
sanimda rašė:
gal gali placiau?
StandartinėParašytas: 02 Kov 2009, 19:03
TT E39 525 98'
sanimda rašė:
:lol: :lol: :lol:
sita pats suprantu :wink:
taip, jei galima placiau apie tai
StandartinėParašytas: 02 Kov 2009, 19:47
E39 523i 98`
M52B25, Steptronic
Kol Sanimda galvos kaip koreguoti lempuciu degimo intervalus, as radau stai kokios info:
I am on a similar schedule as garyd. I don't really pay attention to the service lights, but did/will continue to do the bigger "Inspection II" kinds of things at 60K intervals. Oil every 5500 to 6500 miles, plugs done at 70K, radiator at 50K, etc.
However, here are the "Technical details of the service reminder lights."
Mileage is estimated based on the following formula:
e= a(1+t+r)
e=Estimated mileage
a=Actual mileage traveled
t=1 if engine temperature is below operating temperature, else t=0
r=.5 if engine is above 4500 RPM, else r=0
Example: If you traveled 5 miles with a cold engine running at 5000 RPM, the SII computer would actually "estimate" 12.5 miles traveled:
Solving for e:
a=5 (the actual miles traveled)
t=1 (because the engine was cold)
r=.5 (the engine was exceeding 4500 RPM)
e=5 X (1+1+.5)=12.5 estimated miles (from a trip of only 5 miles)
Once the computer reaches a certain count value (about 7,500 miles for Oilservice and 15,000 miles for inspection, varies from years/models), it will illuminate one of the service lights (oilservice or inspection).
Kaip suprantu kompas apskaiciuoja pagal formule alyvos tarnavimo laika, atsizvelgdamas i temperaturas ir variklio apsukas :)
StandartinėParašytas: 02 Kov 2009, 20:39
protariu Linius, man jau ne vienam servise tai sake. o ir su draugo lyginau, jis megejas padraskyt savo 530i pas ji lemputes gesineje kas 2500-3000km, maniskiam 525tds kas 3000-4000. kompu keiciasi tik pati formules lygtis, tik nesuprantu kam keist, jai gamintojas numates taip tai gal geriau ir nejudint, o tiesiog nepagailet pinigu ant normaliu tepalu? pataisykit jai klystu.
StandartinėParašytas: 02 Kov 2009, 20:47
kaunas
E39 01m.4.4
ex-e34 525 tds 94m.
tiem kur gesta kas 4000 manau kad long life tepalai turi piltis
StandartinėParašytas: 24 Kov 2009, 04:58
BMW e61 530D 04, 160kw
O tai pala, niekas dar neissiaiskino kur pakeisti :) ?
Siaip idomu.
StandartinėParašytas: 01 Bal 2009, 18:37
Mzk
E83 3.0sd 07' SAV
E46 325i 02' sedan ex
E39 520i 98' touring ex
E36 318i 96' sedan ex
3 kartus skirtinguose servisuose bande su KOMPU nuresetinti ir nenuresetino, nes pries tai tie patys mazeikiu KEMI specialistai su laideliais bande ir pridirbo taip kad dabar ir su kompais nieko nepadaro. visa laika dega viena zalia lempute ir viskas. o tie kas cia duoda 100% garantijas tegul pabando
Best Made Wheels - BMW...
StandartinėParašytas: 01 Bal 2009, 20:06
kaunas
E39 530D 99' Tour
as tai atjungiau akuma 3 valandom pakraut, pajungiau, ziuriu-visos zalios, pacios nusiresetino :D
StandartinėParašytas: 01 Bal 2009, 20:20
man su laideliu nusiresetina be problemu, jau kokiom 5 auto taip resetinam ir kolkas nera bedu :) o tas kemi tai tik pavadinimas, pinigus jama vos ne kaip krasta auto, o dirba paprasti megejai minimalia izinantys apie bmw :) čia apie mzk as
StandartinėParašytas: 08 Bal 2009, 14:13
Panevezys
E39 528i m52 98;E46 328i m52tu 98
wytix
Jei pastave skydelis su pilnu bortu ir dega tik viena lempute tai greiciausiai skydelio displejaus beda. Pas pazystama taspats tik pas ji dar 3 uzsidega ir uzrasus sunkiai aina suskaityt. :mrgreen:
LPG POWER
StandartinėParašytas: 08 Bal 2009, 18:45
o pas mane masina ilgai buvo su nusedusiu, t.y. mirusiu akumu, beto buvau isemes akuma ilgam, kol tvarkiau bet nenusiresetino, dege tik 1 lempute, o nuresetinau su laidais.
