Dabar yra 10 Kov 2026, 08:02
Naujos temos kūrimas Atsakyti į temą  [ 850 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3, 4, 5 ... 57  Kitas
StandartinėParašytas: 09 Rgs 2008, 22:48
Chrysler Voyager 2,5CRD 01'
Edvazas
Edvazas
nu del to egr kad tektu keisti turbina tai irgi cia pirma karta girdziu, nes prisiskaiciau jau nemazai apie ta egr, jis tiesiog kaip sakant tausoja musu gamta
o uzglusinimui cia kada ateina laikas? ir paskirtis to kokia?
Ex BMW E39 525tds 97'
Ex Rover 620 SDi 95'
Ex BMW E34 525i M20 88'
StandartinėParašytas: 09 Rgs 2008, 22:55
E39 525D
Vieni i pati EGR imontuoja plokstele, kiti paprastai sratuku slangele uzglusina ...
O del uzglusinimo zinai - kiek meistru, tiek nuomoniu ...
StandartinėParašytas: 09 Rgs 2008, 23:11
Edvazas
Edvazas
bet rimtai ka daro uzglusinimas
StandartinėParašytas: 09 Rgs 2008, 23:24
Min2tis rašė:
Deja lietuviai auksarankiai ir ne tik, atejus tam tikram laikui specialiai uzglusina ta EGR ...o nuo to kad tektu keisti turbina - naujiena ...
Tai pasiskaitykit, jei kam naujiena, kaip tas ERG voztuvas veikia ir kaip itakoja kitus ismetimo mazgus.
When an engine is under load, the very high combustion chamber temperatures produced will increase the amount of NOx. The problem was how to reduce it. The answer - the good ol' EGR valve. This was designed to allow carbon dioxide to be introduced into the combustion chambers as a "coolant" gas. Now like all things produced by man, this valve too had its problems. The EGR valve was designed to open and close at appropriate moments but it could get sticky or even stuck! If it was stuck open, you'd find the engine would have a rough idle or stall. If closed the combustion chamber temperatures would rise under load and you would get "knocking".
Now along comes the turbo. Turbos mean boost and this is created by exhaust gases. Turbos will seize if the exhaust gas temperatures get very high for longish periods as the lubrication will fail due to the increased heat. So if the EGR valve is stuck closed, you've got expensive problems in the pipeline!
I will not go into how the EGR is activated but some are (were) mechanical and some part so with a combination of electronics. They are usually electronic with some exceptions! Now here lies one big problem. Some manufacturers have notorious reputations for poor electronic components and we frequently read about unfortunate people who have turbo failures on their cars. And replacement is not cheap folks - you are looking at a couple of grand or more so the next time your engine starts "knocking" under load or there's a bit of a whistle, don't think about changing plugs if it's a petrol engine or fuel brand, rush down to the dealer with a letter (and keep a copy) saying you are worried that the EGR valve is not functioning properly. Prevention is one hell of a lot cheaper than cure!
And if you have had a turbo replaced, check the service invoice and see if a new EGR valve was fitted. If not, and it's a "sticky" one, then in time the new turbo could fail too!
Hope this helps some of you in the future.
StandartinėParašytas: 13 Rgs 2008, 12:46
Toyota Corolla Verso
man irgi reiktu pagalbos issifruojant klaidos pranesima:
VERIF. FEUX AR
gal kas zinot ka reiskia? per google tik rusu saite radau kad galbut su stabdziais susije. Gal kas nors galetu patvirtinti ar patikslinti?
StandartinėParašytas: 13 Rgs 2008, 13:34
Panasu kad VERIF. FEUX AR reiskia CHECK BRAKE LIGHTS. T.y. pasitikrink stopus :wink:
StandartinėParašytas: 14 Rgs 2008, 18:38
Ačiū, padejo.
Isemiau lemputes, apziurejau, pasirode sveikos, atgal idejau. Pranesimas nebesikartoja. Gal nekontaktavo kas
Man anksciau buvo VERIF FEUX STOP pranesimas, maniau jis del bet kurios is stabdziu lempuciu, tada buvo perdegus virsutine, kur galinio stiklo apacioje.
Ar VERIF FEUX STOP virsutinei lemputei, o VERIF FEUX AR kitoms? :?
StandartinėParašytas: 19 Spa 2008, 15:45
E39 523i 1997m
sveiki pasidariau diagnostika ismete erora,ka tai gali reiksti ka cia keisti reikia?gal pas ka tas pats buvo?
E39 2.3l benzas
dme.JPG [ 73.22 KiB | Peržiūrėta 18145 kartus(ų) ]
StandartinėParašytas: 19 Spa 2008, 16:55
56 резисторов Текущей обратной связи воспламенения: Разомкнутая цепь
Проверите сигнал обратной связи воспламенения.
tipo patikrinti degimo atgaline srove nes atjungta grandine ar kazkas tokio :}
o del airbag tai manau viskas aisq :} trink klaidas ir vazinek jei viskas veik
StandartinėParašytas: 19 Spa 2008, 19:34
E38 740d ex
E60 530d ex
e60 530d Lci ex
e65 745d individual
Is kur paimt klaidu kodu reiksmes pas mane ismeta not faund
StandartinėParašytas: 19 Spa 2008, 20:01
http://bmwpower-bg.net/forums/viewtopic.php?t=42392 sita turejiai omeny ? :}
StandartinėParašytas: 20 Spa 2008, 13:17
E39 523i 1997m
TAI ISTRYNUS KLAIDA TA 56 VEL ATSIRANDA...TAI CIA KAS BUT GALI SU ELEKTRA? ZVAKES KOKIOS?
StandartinėParašytas: 20 Spa 2008, 18:21
E39 523i 1997m
tai as pats suprantu kad ner kontakto bet kurioj vitoj kokia fiske nekontaktuoja?
StandartinėParašytas: 20 Spa 2008, 18:45
JK arba Klaipeda
dabar valdiska :)
ex E39 530d '01
ex E34 520i '91
Imi WDS, susirandi uzdegimo elektro schema ir bandai ieskot, kur stovi koks rezistorius, ar dar kitu itratinu vietu. Po to testeri i rankas ir pirmyn ieskot kontakto :wink:
Arba varai i servisa ir nesuki kiausiu :D
P.S. Neisizeisk, bet nieks tau tiksliai nepasakis kurioj vietoj konkreciai pas tave nera kontakto. Keikvienas atvejis gali buti skirtingas.
StandartinėParašytas: 20 Spa 2008, 19:29
o tau masina nevaziuoja, ar neuzsiveda ? ar seip ligu ieskai ?
