Dabar yra 19 Sau 2026, 11:41
StandartinėParašytas: 29 Lap 2007, 13:15
123ed
taspas
Koks padangų slėgio kontrolės (RDC) veikimo principas?
Makita, Hitachi, Nilfisk-Alto ir kiti profesionalūs elektriniai, akumuliatoriniai, pneumatiniai, hidrauliniai, rankiniai įrankiai bei įrankių priedai - www.gitana.lt
StandartinėParašytas: 29 Lap 2007, 13:29
ex E38 735 M62 97'
ex E39 520 M47 00' Touring
ex E34 530 M60 94
turetu but vintiliuose dacikai, is kuriu ir gauna info tas modulis apie slegi.
StandartinėParašytas: 29 Lap 2007, 13:33
123ed
taspas
runcikas rašė:
Nėra jokių daviklių, bet va radau straispnį...
Cituoti:
Wheel-Speed Based Pressure Sensing
The direct pressure sensing approach described above requires new hardware - the pressure sensors, receiving antennas, and display. So why not instead use sensors already in the majority of new cars - the wheel-speed sensors used in traction control and ABS applications? By using the wheel speed sensors to detect tyre-to-tyre differences in straight-line wheel speeds, an under-inflated wheel can be identified. This is because the rolling radius of the wheel will decrease with a drop in pressure, and so relative to the other wheels, it will rotate more quickly.
However, while an elegantly simply approach, it does have some major downsides. The wheel-speed based pressure sensing approach is used in the 2001 BMW M3 convertible and 750iL models. In the M3 owner's manual the following warnings are made:
The system cannot alert you to severe and sudden tyre damage caused by external factors.
The system will not identify the natural, even loss of pressure in all four tyres.
Under certain circumstances, there may be false warnings or a delayed detection of losses in pressure when driving on snow-covered or slippery road surfaces.
A sporty driving style (slip at the wheels receiving the torque, high lateral acceleration) can lead to delayed system warnings.
StandartinėParašytas: 29 Lap 2007, 14:41
Jei trumpai, tai remiasi ABS'o dacikais ir jei pamato, kad vienas ratas pradeda greiciau suktis nei kiti, vadinasi sumazejo jo diametras ir padangoj truksta oro.
StandartinėParašytas: 29 Lap 2007, 19:10
Yra ir RDC sistema(su slegio davikliais ratuose ) ir yra RPA sitema (naujesne nuo 2003m kur remesi ABS davikliais ).Jeigu nera ratlankiuose davikliu ,tai arba ratlankiai ne orginalas,arba tiesiog pakeisti i ratlankius kurie neturi davikliu.
BMW E34 525 M51 tds touring (ex). BMW E39 M57 525d (ex). BMW E39 M57 530d touring(ex) BMW E38 M67 740d (ex).BMW E39 M57 530d (ex) BMW E65 N62B48b 750i (ex) BMW E46 Coupe M47TU
StandartinėParašytas: 29 Lap 2007, 20:31
pasmane yra ratuose tie davikliai, bet daznai jis acijungia. speju dacikus reik keist, skaiciau kazkur forume kainuoja apie 1000lt ir reikia keisti kas 5m (del kainos gerai nepamenu bet zinau kad nepigus)
StandartinėParašytas: 04 Gru 2007, 11:03
E30 320 88'
Pas naujus XXXXXXXX automobilius stovi davikliai ratlankiuose (daviklis su ventiliu). Prie ratu, arkose stovi siustuvai/imtuvai, kurie siuncia signala davikliui ir is jo gauna atsakyma, kokis yra slegis. Dazniausiai saibom pareina davikliai, laidu jungtys. Patys siustuvai sugenda laaabai retai.
O sistema, skaiciuojanti rato pakitimus nuo ABS sistemos, kazkokia nesamone man gaunasi. Visu pirma turi buti ziauriai tikslus griacio skaiciavimas. Po kablelio min. 3-4 skaiciai. Turi buti vairo padeties davikliai, apkrovu davikliai r pan, kad sistema neapsigautu ilguose posukiuose, uzkrovus tik viena automobilio puse.
StandartinėParašytas: 04 Gru 2007, 17:41
E36 320 M50 91' sedanas
marius_darbe
Virgis rašė:
OT: jau matau perpektyva pacukams - sukinėti tokius ventylius lauk :)
StandartinėParašytas: 04 Gru 2007, 22:52
Vilnius - Panevėžys
ex E36 320 M52 94'
E46 M47tuD20 03'
Įtariu_BITES rašė:
Pacukai butu nesusiprate, o tu padejai suprasti :lol: Sakyciau reikia salinti sia minti, kol nepamate tas kam negalima :)
StandartinėParašytas: 05 Gru 2007, 00:05
Grill rašė:
Įtariu_BITES rašė:
Tos ventilius su davikliais kad issukti,reikia padangas numontuoti.
StandartinėParašytas: 05 Gru 2007, 09:20
E30 320 88'
Tautietis rašė:
Grill rašė:
Įtariu_BITES rašė:
Tikrai taip. Neismontavus padangos tu davikliu neimanoma isimti. O is isores jie labai nesiskiria nuo standartiniu, siek tiek patiuninguoti. O ir isidejus ta davikli i savo masina, naudos bus panasiai tiek, kiek is ozio pieno. Nes dar reikes siustuvo/imtuvo, proco informacijai apdirbt ir displejaus informacijai pateikt.
StandartinėParašytas: 05 Gru 2007, 09:21
marius_darbe
Virgis rašė:
tai jau tikrai, pacukai laupydami mašiną masto apie tai kaip visa tai pritaikys savo golfui :D
StandartinėParašytas: 05 Gru 2007, 10:10
Siaip jau Hella gamina toki komplekteli :) i komplekta iena keturi vintyliai su davikliais, kontrolinis blokas ir displejus viso komplekto kaina 850,- lt :) jei kas susidomejot butu galima parvezti :)
http://www.hella.com/produktion/HellaRe ... EN_HSG.pdf
