Dabar yra 05 Kov 2026, 09:47
Naujos temos kūrimas Atsakyti į temą  [ 33 pranešimai(ų) ]  Eiti į 1, 2, 3  Kitas
StandartinėParašytas: 19 Vas 2007, 12:25
Dublin
GSX600FK2
Radau toki straipsneli, tik man niekaip nepavyko ant savo E30:
Did you know that your BMW 3 Series has an internal diagnostic program built into the computer? Not many people know about this. On the BMW 3 Series, there is a way that you can diagnose common engine problems without having to purchase a code tool or take it to the dealer to have it scanned. This is one of those neat little features of the Service Indicator Computer; the series of lights directly under the tachometer and speedometer that remind you to change the oil and perform service. In this tech article, I will provide you with the procedure for checking the fault codes and what the codes mean. This guide will help you to diagnose any possible problems with your car.
This article is written for both the BMW E30 and E36 3 Series cars (up to 95) and should work on both models where a Service Indicator Computer is used. I will go over the small differences between the early and late cars, as they differ slightly. Keep in mind that this procedure will not work on early cars with Motronic 1.1.
Now on the E30 models, get in the car and put the key in the ignition and turn it to the second turn or “ON” position, but do not start the car. Now, press the accelerator pedal all the way to the floor, then let it release all the way back. Now repeat the depress/release cycle 4 more times fairly quickly, but not too fast. It may take some time to get this timing down correct. It should only take you a few seconds to do this. What this does is activate the wide-open throttle switch and the idle switch 5 times. This then sends a signal to the Motronic ECU to send fault codes to the Service Indicator Light.
On the E36 models, the procedure works the same way, but the timing at which you press/release the gas pedal is faster than on the E30. Just keep at it, and you will eventually get the correct speed.
Watch the “Check Engine” light. It should blink once, and then start blinking a series of four numbers. For instance, say this is a sequence you see… the light blinks once, then twice, then four times and lastly four times. If you read it correctly this means that the SI light is reading out the code 1244 (faulty camshaft sensor) The codes appear as a series of flashes for each digit. The flashes indicating one digit are about one second apart, the next digit will appear after a couple seconds interval. If there are no faults in the car, the computer will flash out the number 1444.
Here is the list of codes and what they indicate.
1211 DME Control Unit
1215 Air Mass Sensor
1216 Throttle Potentiometer
1218 Output Stage, Group 1
1219 Output Stage, Group 2
1221 Oxygen Sensor 1
1212 Oxygen Sensor 2
1222 Lambda Control 1
1213 Lambda Control 2
1223 Coolant Temperature Sensor
1224 Intake Air Temperature Sensor
1225 Knock Sensor 1
1226 Knock Sensor 2
1227 Knock Sensor 3
1228 Knock Sensor 4
1231 Battery Voltage/DME Main Relay
1232 Throttle Idle Switch
1233 Throttle Wide Open Throttle Switch
1234 Speedometer A Signal
1237 A/C Compressor Cut Off
1242 A/C Compressor
1243 Crankshaft Pulse Sensor
1244 Camshaft Sensor
1245 Intervention AEGS
1247 Ignition Secondary Monitor
1251 Fuel Injector 1 (or group 1)
1252 Fuel Injector 2 (or group 2)
1253 Fuel Injector 3
1254 Fuel Injector 4
1255 Fuel Injector 5
1256 Fuel Injector 6
1257 Fuel Injector 7
1258 Fuel Injector 8
1261 Fuel Pump Relay Control
1262 Idle Speed Actuator
1263 Purge Valve
1264 EGO Heater
1265 Fault Lamp (check engine light)
1266 VANOS
1267 Air Pump Relay Control
1271 Ignition Coil 1
1272 Ignition Coil 2
1273 Ignition Coil 3
1274 Ignition Coil 4
1275 Ignition Coil 5
1276 Ignition Coil 6
1277 Ignition Coil 7
1278 Ignition Coil 8
1281 Control Unit Memory Supply
1282 Fault Code Memory
1283 Fuel Injector Output Stage
1286 Knock Control Test Pulse
1444 No Fault Codes
P.S. paimta is http://www.bimmerdiy.com/E30
StandartinėParašytas: 19 Vas 2007, 20:28
E60 B54B25
Na jai kas i lietuviu kalba isverstu ir as babandyciau :wink:
StandartinėParašytas: 19 Vas 2007, 20:35
idomu... reiks pameginti :) bet kazkaip abejoju ar suveiks :)
StandartinėParašytas: 19 Vas 2007, 22:23
X5 xDrive30d '09
fructazz
Cia kiek zinau, tik ant amerikiniu veikia :(
StandartinėParašytas: 19 Vas 2007, 22:35
ex E38 735 M62 97'
ex E39 520 M47 00' Touring
ex E34 530 M60 94
teko panasu straiipsni skaityt ir e34-tam, veiksmai tokie patys, bet man tas dalykas nesigavo (ant E34 M60B30 )
StandartinėParašytas: 20 Vas 2007, 12:10
Dublin
GSX600FK2
efkav rašė:
Sita "baika" veikia tik su naujesniu kompu nei Motronic 1.1;
Pastatai rakteli i degimo padeti, bet neuzvedineji masinos. Letai spaudi akseleratoriaus pedala iki pat dugno ir atleidi, tada dar 4 kartus tik greiciau suspaudai iki dugno ir atleidi (isviso 5kartus, reikia pagauti intervalus). Tada viena karta sumirkcioje "check" skydelyje ir pradeda rodyti kodus tos zalios lemputes :)
StandartinėParašytas: 20 Vas 2007, 16:11
http://www.aet-tendahl.de/motorsteuerge ... te-bmw.php
buvau ir as nuejes paminkyt pedalo, bet nesigavo nieks, sakau gal cia signalizacija kalta gali but, nes as kai degima ijungiu tai uz keliu sek. uzsirakina durys ir sakau gal sumaiso visa reikala
StandartinėParašytas: 20 Vas 2007, 16:34
pas mane irgi neveikia, arba ne tuo intervalu pedala minkom... o signalke neturetu itakos daryti, nes kompas gi signalkes neitakoja (nebent kokia gamykline). beje, neuzdaryk duru ir neuzsirakins :) cia greiciau neskirta musu auto tokie "navarotai".
StandartinėParašytas: 20 Vas 2007, 16:38
all in music rašė:
na gal, bet toj nuorodoj kur daviau raso, kad bent pas mane stovi motronicas 1.7, nebent nera to DME, check funkcijos..
StandartinėParašytas: 20 Vas 2007, 17:11
pagal tavo nuoroda pas mane "320i 2 litre (6 cyl) 92-95 Bosch Motronic 3.1" tik pas mane siemens sistema... ar motronikas gali buti bosch? nors nelogiska butu...
cia kazkas tiksliau galetu pasakyti, jei kam pavyks toks patikrinimas... :) idomu pedala kaip ten minkyt reikia... gal per letai viskas daroma, arba per greitai, o gal isvis nera musu masinose tokio daigto :)
StandartinėParašytas: 20 Vas 2007, 17:12
Dublin
GSX600FK2
Vytenis rašė:
Pas mane Motronic 1.3 ir Check Control yra, tik OBC nera. Dar bandysiu pirma paspaudima labai leitai uzlaikydamas paspaudineti.
P.S. Check Control - tai kur virs veidrodelio rodo info jei perdega lempute, truskta skysciu..?
StandartinėParašytas: 14 Kov 2007, 14:54
Dublin
GSX600FK2
Stai ka dar radau:
Fault codes for euro-e30
My euro 325i '90 has no check engine light. Because I knew that the Motronic would produce fault codes anyway , and did some research. It appears that the codes are output to pin 15 of the computer, but the wire stops at pin 12 of the big connector in the engine compartment next to the fuse-box.
By using a little 12V light connected to pin 12 of this connector and +12 V, the codes appear after pushing the gaspedal 5 times (contact on).
Works great! Let me have your experiences.
Paimta is: http://www.bmwe30.net/cgi-bin/datacgi/d ... Section=14
StandartinėParašytas: 14 Kov 2007, 16:14
Tankai, idomu, idomu.. tai kaip ir reiktu lempute i salona atsivest..
StandartinėParašytas: 14 Kov 2007, 17:05
Dublin
GSX600FK2
Vytenis rašė:
Nebutinai, juk kiekviena diena netestuoji ar meta kompas klaidas ar ne. Tik isbandyti reiketu ir parasyti cia ar veikia.
Nes kaip suprantu primas post'as kur parasiau tai skirtas USA, o EURO versijom tai reike lempotes viena kontakta prie 15-kto kontakto ir akumo + teigiamo poliaus.
StandartinėParašytas: 14 Kov 2007, 17:11
tai ir sakau kad idomu :)
bet lempute vistiek reiktu atsivest, nes gaza maigysi tai salone sededamas, siaip pas mane yra CHECK skydeli, bet nepavyko sumaigyt..
