Dabar yra 04 Kov 2026, 04:26
Naujos temos kūrimas Atsakyti į temą  [ 644 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 32, 33, 34, 35, 36, 37, 38 ... 43  Kitas
StandartinėParašytas: 27 Rgp 2016, 17:04
E60 530
Kaip suprantu mano akumas ir mpm modulis i pabaiga?
iPhone Fault Report - Carly for BMW - 25.98 - 2016.08.24.1755 FV
ID1: D712964A-F6AA-4D93-885C-B625FD4F6E70-348-0000004C48B8BECA-a3a
ID2: 20011D48-52A8-4CC2-9129-BFA8A79D7BBA-348-0000004C48B8BF7D-11f8
INFO: >0009DECDC7AB9A9578675D4737258<
2016-08-27 16:59:44
BASE: E60 E61
BUILD-YEAR: 2005
MODEL: 5 (E60) 530 d alle/all (34)
FAULTS: 17
ECUs: 37
BATTERY: 13.9V
DEPTH: Normal communication
SPEED: slow
CONNECT: Fast Connection
VERSION: 9.3.4
DEVICE: >Audrius iPhone< >iPhone OS<
WIFI: >Tenda v00<
ELM: >ELM327 v1.4 v18<
COM+: >UNKNOWN<
0. Motor Control:
Engine / Motor:
- Fault: Fuel Filter
- Code: 004587
1. ABS / DSC / Brake:
Active Roll Stabilization / Rollstabilisierung:
- ECU OK, no fault code
Dynamische Stabilitaets Kontrolle / DSC:
2. Airbag:
Advanced Crash and Safety Management (ACSM):
- Fault: sorry, unknown DTC fault
- Code: 004587
Satellite front left door / Tuer vorne links:
Satellite front right door / Tuer vorne rechts:
Satellite B-pillar left / B-Saeule links:
- ECU not present/no answer
Satellite B-pillar right / B-Saeule rechts:
Satellite center / Mitte:
- Code: 009AFF
Airbag B-pillar left/ B-Saeule links:
Airbag B-pillar right/ B-Saeule rechts:
3. Transmission Control:
Transmission / Getriebe GS 19:
Transmission / Getriebesteuerung:
Gear switch / Gangschalter:
4. Instrumentation:
Instrument cluster / Kombiinstrument:
Central info display / Zentrales Display:
- Fault: Central control timeout
- Code: 00A468
Head-Up Display:
5. Light/Rain Control:
Light / Licht:
Rain/light sensor / Regen-Lichtsensor RLS:
Light / Licht:
High-beam / Fernlichtassistent:
6. Heating / AC:
Air conditioning / Klimaanlage:
Additional heater / Zusatzheizung:
7. Immobilizer System:
CAS:
8. Park distance control / PDC:
Park Distance Control / PDC:
9. Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung:
10. Sunroof / Roof:
Sunroof / Schiebedach:
11. Audio / Navigation / Communication:
Multimedia-Changer / Wechsler:
Speech recognition / Spracherkennungs-system:
Phone / Telefon:
Hifi Amplifier / Verstaerker:
Tuner Antenna / Antenne:
Hybrid Radio USA:
Digital Satellite-Tuner USA:
Headphones / Kopfhoerer Schnittstelle:
Navigation:
CD-Changer / Wechsler:
Audio-System:
Video:
- Fault: ring diagnostic check error
- Code: 00DBD0
- Code: 00A39A
- Fault: Remote Charging voltage out of tolerance
- Code: 00A38F
DAB:
12. Seats:
Backrest width / Lehnenbreiteverstellung:
Seats / Sitze:
Seats / Sitze:
13. Systems:
Gateway:
Steering column switch / Lenkstockschalter:
Fuel pump / Kraftstoffpumpe:
Tire pressure control / Reifendruck Kontrolle:
Passive Go System:
Power Module:
- Fault: Relay 1 is defective
- Code: 00A6A7
- Fault: fuse current 1
- Code: 00A6A9
Night Vision:
Flexible Bus-Interface / Schnittstelle:
Car Communication Computer CCC:
- Fault: Message failure
- Code: 00E18F
- Fault: Over-/undervolt- internal voltage
- Code: 00A179
- Fault: unknown failure
- Code: 00E18C
MASK:
Center-Konsole:
Night Vision Camera:
Car Communication:
14. Anti-theft alarm system:
Interior protection / Innenraumschutz:
Theft alarm / Diebstahl Warnanlage:
15. Chassis:
Air suspension / Luftfederung:
Electronic damper / Elektronische Daempfer:
Central Control / Zentrale Bedieneinheit:
16. Body:
Automatisches Front Steering:
- Fault: motor position sensor
- Code: 006136
- Fault: driver's steering wheel angle
- Code: 006140
- Fault: monitoring missing
- Code: 006145
- Code: 00614A
- Fault: Steering wheel angle
- Code: 00CE93
Trailer / Anhaenger:
Car Body Module:
Tailgate / Hecktuer:
17. Other:
BMW - Baisiai Malonu Vaziuoti
StandartinėParašytas: 17 Rgs 2016, 15:35
E39, 530d 99m
e60 530d 08m LCI
Sveiki, man rodo klaida kodas 009C6B auxiliary water pump mano automobilyje webastos nera kiek skaiciau dazniausia su webasta ismeta ta klaida. Gal kas zinot ka cia turi omenyje ta klaida kai nera webastos?
StandartinėParašytas: 18 Rgs 2016, 14:04
E60 525d
siurbliukas prie kiausu, rest funkcijai, ir siaip ziema salonas be jo sunkiau syla
StandartinėParašytas: 18 Rgs 2016, 15:36
E39, 530d 99m
e60 530d 08m LCI
cia turi omenyje apie 5 detale? https://www.bmwautodalys.lt/lt/kataloga ... /0/2008/06
StandartinėParašytas: 19 Rgs 2016, 09:35
E60 525d
Tas pats
StandartinėParašytas: 19 Rgs 2016, 22:47
_minde_ rašė:
labas,man taip pat parode tokia klaida,Papildomas vandens siurbliukas,, naujas 73 eurai.
StandartinėParašytas: 20 Rgs 2016, 12:38
Kazkur skaiciau, kad net neeme to siurbliuko, tik atsisuko pati virsu, pasikeite angliukus ir vel OK
StandartinėParašytas: 20 Rgs 2016, 13:00
Angliukus pasikeisk ir vel veiks...
StandartinėParašytas: 20 Rgs 2016, 13:06
E65 730d M57N
E60 530d M57N
Opel Astra H TwinTop
Kawasaki zx12r
Suzuki SV650
E39 540i M62 manual (ex)
E34 530i M60 manual (ex)
Yamaha YZF-R1 98m. (ex)
Mycius
E38/E39 taip, galima pasikeist angliuku, bet šitam nieko neišeis, jis sulietas visas. Buvau jau vieną tokį išardęs, nėra ten ka remontuot, jei nustojo veikt.
StandartinėParašytas: 20 Rgs 2016, 13:46
Radau ta tema dionich savo E91 pasikeite, nu taip detales kodas kitas.......
Cituoti:
Pompos varikliuką išardžiau ir pakeičiau šepetėlius. Pompa randasi patogioj vietoj lonžerone, ir nereikia nuiminėt šlangų. Užtenka nuimt varikliuko galva, kurioje ir randasi šepetys.
StandartinėParašytas: 20 Rgs 2016, 14:19
E65 730d M57N
E60 530d M57N
Kawasaki zx12r
Suzuki SV650
Mycius
Taip išeina, reikia žiūrėt kiekvienu atveju atskirai. Man su e65 varikliuku nieko neišėjo, nes kaip ir minėjau jis neardomas (tos kaip nuotraukoje viršuje).
StandartinėParašytas: 20 Rgs 2016, 17:29
E60 525d
as ir keiciau,buvo kaip virsui, is e65 gavau, gal uz 20 lt dar, sukasi iki siol
StandartinėParašytas: 25 Rgs 2016, 16:17
E39, 530d 99m
e60 530d 08m LCI
Antifriza reikia isleisti ji keiciant ar ten jo nedaug nubega?
StandartinėParašytas: 25 Rgs 2016, 21:25
_minde_ rašė:
as spejau uzkist slangu pabaigas,gal truputi ir nubego,bet tai [CENZŪRA].
StandartinėParašytas: 26 Rgs 2016, 16:05
kiesha rašė:
kaip jums Rusai pavaro ,cia tik mes verkiam =D>
https://www.drive2.ru/l/8706388
