Dabar yra 21 Bal 2026, 17:21
Naujos temos kūrimas Atsakyti į temą  [ 458 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 19, 20, 21, 22, 23, 24, 25 ... 31  Kitas
StandartinėParašytas: 12 Bal 2013, 14:17
F06 640i
Nezinau, pirkau China 25w - sviete blogiau, nei dabartiniai MTEC V3 6w. Kainu skirtumas dvigubas...
StandartinėParašytas: 12 Bal 2013, 14:26
Dedi 10W max stipresni pinigu svaistymas ryskiau nedegs.
StandartinėParašytas: 12 Bal 2013, 14:47
Gal kas turit ar siaip galit pakomentuot:
20W 10W CREE Angel eye LED upgrade units BMW 5 SERIES E60 E61 03-07 2013 MODEL
20 Watt CREE (10W EACH SIDE) Series LED angel eye upgrade bulbs. Brightest LED bulbs on the market guaranteed!! (AS of March 2013)
Super bright 6000K light
Low Heat
No computer errors
Nearly as bright as the new BMWs with factory fitted LED rings
Install Instructions can usually be found on youtube although we do have a install Videos if you need them.
Simple bulb swap
No Radio Interference
NO CANBUS ERRORS
This is a pair of High power LED bulb units to upgrade from standard 3000K rings to bright white xenon colour 6000K rings. You must have OEM rings installed when the car was made. This was usually an optional extra at the time.
White is fully road legal. You may notice they flash for about 5 seconds on startup. This is perfectly normal and can sometimes stopped by starting the car with auto lights turned on.
$(KGrHqZHJEcFE1ey6gWEBRNz0Q4,rw~~60_35.JPG [ 31.05 KiB | Peržiūrėta 7527 kartus(ų) ]
20WCREEE39-LIT.jpg [ 42.73 KiB | Peržiūrėta 7527 kartus(ų) ]
e60-dark.jpg [ 29.51 KiB | Peržiūrėta 7527 kartus(ų) ]
Paskutinį kartą redagavo Darenasp 12 Bal 2013, 14:52. Iš viso redaguota 1 kartą.
StandartinėParašytas: 12 Bal 2013, 14:49
E61 523i '05
Vatai ir kelvinai neturi jokio rysio. Sviesos spalva nusako kelvinai, o stipruma - vatai. Perkant tiesiai is Kinijos 2 komplektus, kaina nuo kokiu 13 $ prasideda. :D
O ka kinieciai raso del vatu - nereikia aklai tiketi. Gali rasyti ir 100W, bet realiai tokiose lemputese LED galingumas bus 2-3 W. 10 vatu LED diodas atrodo visai kitaip ir jam reikia didelio ploto ausinimo radiatoriaus.
Paskutinį kartą redagavo VytasM 12 Bal 2013, 15:00. Iš viso redaguota 1 kartą.
StandartinėParašytas: 12 Bal 2013, 14:55
Vilkaviškis-Vilnius
ex: E61 530d+ 05'
darenasp rašė:
Low Heat
No computer errors
Simple bulb swap
NO CANBUS ERRORS
Čia pre-LCI? Mane taip pat tokios domintų. Gal gali nuorodą įmesti?
StandartinėParašytas: 12 Bal 2013, 16:05
F06 640i
darenasp rašė:
Sis sakinys jau duoda suprast, jog China shit... Tie, maniskiai, ale 25w taip pat mirksejo. MTEC jokiu mirksejimu...
P.S Ir 99% garantuoju, jog nesvies kaip foto :wink:
StandartinėParašytas: 12 Bal 2013, 16:13
Ciakas rašė:
Duok nuoruoda is kur pirkai Mtec, gal gali savo foto padaryt kaip sviecia?
StandartinėParašytas: 12 Bal 2013, 16:20
F06 640i
Ok, kada nufotkinsiu. O, dabar gali zvilgtelt palyginima MTEC V3 VS MTEC V2
Pirkau EBAY.CO.UK, pardavejas hids-direct.
StandartinėParašytas: 12 Bal 2013, 21:03
E60 535d M57N2 '08
E46T 320d M47N '04
E88 120d N47 '12
Tai jeigu aš teisingai randu pas nurodytą pardavėją kaina 79 Angliški svarai. Paimčiau. Kaip čia pigiau prasisukt. Derinkimės.
StandartinėParašytas: 12 Bal 2013, 22:07
Vilkaviškis-Vilnius
ex: E61 530d+ 05'
Mesčiausie prie group-buy. :)
StandartinėParašytas: 13 Bal 2013, 00:41
littlem rašė:
+1
GAL RIMTAI KAS APSIIMTU ORGANIZUOTI SI DALYKA, MANAU NE VIENAS ATSIRASTU NORINTIS.
http://www.ebay.com/itm/370729347564?ss ... 1438.l2649
Paskutinį kartą redagavo Darenasp 13 Bal 2013, 09:35. Iš viso redaguota 2 kartus.
StandartinėParašytas: 13 Bal 2013, 09:13
E65 740d matte black
jei ziedus pasikeiti, kazkaip butu smagu ir priesrukinius pakeisti i LED dienos sviesas, tik kiek domejaus, ten gan sudetinga visa tai padaryti..
StandartinėParašytas: 13 Bal 2013, 09:26
Dainiusz rašė:
Priesrukiniu neliesciau vien del tech. Apziuros, nepraleis modifikuota orginala.
StandartinėParašytas: 13 Bal 2013, 11:44
E60 535d '2006.06
Gal esat kas i lci lempas isideje h8 10w markerius? Mtec firmos ebay yra nuo 100 svaru o is kinijos parsisiust galima uz 100litu kazi ar didelis skirtumas
StandartinėParašytas: 13 Bal 2013, 12:31
E60 535d M57N2 '08
E46T 320d M47N '04
E88 120d N47 '12
darenasp rašė:
+1
Pritariu, gal rimtai kažkas užsiimtų kas su ebėjum draugauja ir turi praktikos. Siuntimo išlaidas išdalintumėm, gautųsi pigiau. O Lietuvoje paskui per pašto siuntas išmėtytų už kažkokį simbolinį mokestį.
