Dabar yra 15 Sau 2026, 07:59
StandartinėParašytas: 19 Geg 2007, 14:57
neturiu kuo pasigirti :)
gal kam pravers:
Obtaining secrets from the Check Control (E38)
The Check Control in the instrument cluster of the current BMW 5/7series hides somes secrets. Here is the procedure how to unveil them and how to unlock the system to get access to all tests:
Turn ignition to pos. II
Push right button in the instrument cluster and keep it pushed. You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits together and write down that number, you will need it for unlocking all the functions. Example: DG23278 will lead to 2+3+2+7+8 = 22
Push the right button until you see "Test Nr.19"
Push left button until you see the number that is equal to the one you calculated above
Push right button again
Now you will have unrestricted access to Test No.3-21. If you made an error in the procedure mentioned above, Test No.3-21 will only display Lock:ON
Most of the tests are self-explaintory, and here is a first listing (as far as I can recall):
1. Display Car's identification number, HW/SW version, date of construction
2. A very beautiful instrument test
2. Current consumption (liters/100 km)
3. Current consumption (liters/hour)
4. Average consumption (liters/100 km)
5.Current range
6. N/A
7. Average fuel in tank (liters)
8. Current Speed (kph)
9. System voltage at Term. "R" (Battery Voltage)
10.Country/Language (US, Spa, Ger, Jap, etc.)
11. Units am/pm
12. Average Speed
13. ETA
14. Date of Software Mask
15. Production Diagnosis
16. ""
17. Display Vehicle Specific Data
18. Alarm Changeover (cont. vs. intermittent OBC chime)
19. Lock/Unlock
20. Correction factor for fuel consumption (nicht ändern!)
21. Reset all defect codes
1. several numbers and data
2. [Dispay Test]
3. VBR: x,x (liters/hr)
4. RW-VBR: x,x (liters/100 km)
5. RW: x (km)
6. N/A 7. TMTL: x,x (liters)
8. V: x (kph)
9. UB: xx,xx (V)
10. LAND: 2=USA, 3=I, 4=E, 5=J, 6=F, 7=CDN, 8=AUS/GOLF, 0=D, 1=GB
11. EINHEIT 1: B3, B4, B5, B6, B7, B8, B9, BA, BB, BC, BD, BE, BF, B0, B1
EINHEIT 2: [similar to above, I didn't want to mess with it]
12. VANK: xx,x (kph)
13. ANK:xx:xx
14. ROM:
15. DIAG: 01 01 000 E3
16. PORT: 01 101010000, 02 101010000, 03...etc
17. PROM: 00 12, 01 37, 02 18, 03 E6, 04 02, 05 B3, 06 FF, 07 7E
18. HORN: DTON or [DTON flashing]
19. LOCK: ON
20. KVBR: 1000
21. RESET?
Watch TV / Videotext during driving
This works on all 5/7 Series with the Mk. I Navigation System (the one with the male voice). On Mk II (the newer version with the female voice) you have to use "brightness" instead of contrast for TV and "color" instead of brightness for videotext to get the trick to work. I know that the trick works on latest 99 7series models as well. But I heard also that some cars sold into the US do not have any TV equipment on board. You will notice this as they do not have any TV option in the main menu. Also latest BMWs sold in Europe (2000 onward, 3/5/7 series) have the trick disabled! The only chance to get the TV running is somewhere hidden in the menu of the BMW Sevice Tester DIS. But up to now I can't thell you where. If I ever find it out, I'll post it here!
As far as I know the software update for latest navigation CD Roms does not affect or disable this trick.
Set ignition to pos. II
enter TV mode
enter "settings"
enter "contrast"
when the green contrast bar is visible, push the knob and keep it pressed
turn ignition off (keep button pressed!)
wait 8-10 seconds (timing must be accurate!)
release the knob
turn on ignition again
Now you can watch TV during driving (but always keep at least one eye on the road - that said)
StandartinėParašytas: 18 Bir 2007, 23:23
Idomus dalykelis :D Katik viska isbandziau ,bet kilo vienas klausimelis...Ten
funkciju sarase Nr.21 yra "Reset all defect codes" ar sio yrankio pagalba galima uzgesinti "AirBag" lempute? Nors asmeniskai man nieko neisejo.Gal kam pavyko?
StandartinėParašytas: 14 Spa 2007, 12:53
o lietuviskai arba rusiskai niekas negaletu isversti? :oops: :D
StandartinėParašytas: 14 Spa 2007, 14:03
Klubo Prezidentas
Klubo Prezidentas
Garažėlis
E28 528i ex
E28 524td crash
E28 M535i restoration
E30 318i ex
E32 730i ex
E36 318ti crash
E36 3**i sedan sport edition
E38 740i family car ex
F10 530DxDrive
Rolkis
andree rašė:
Versk kiek tik nori ;)
http://translate.google.com/translate_t?langpair=en|ru
StandartinėParašytas: 14 Spa 2007, 18:46
dekui, labai geras linkas :!:
o griztant prie temos, nieko negalima pridaryti masinai su tais testais? :D
StandartinėParašytas: 28 Kov 2012, 03:07
Vilnius/Panevėžys
BMW 730d '00
Nissan X-Trail 2.2 DCI '02
Ar ka nors bandyt pasidaryti kad rodytu tv vaziuojant pagal virsuje parasyta instrukcija? Ar tai veikia?
StandartinėParašytas: 28 Kov 2012, 11:55
Sostinė
veikia.
StandartinėParašytas: 28 Kov 2012, 19:06
Man kolega prisijunge su kompu ir atrakino NaviIV
StandartinėParašytas: 28 Kov 2012, 19:38
auBi A6 2.5tdi+chip
ex E38 740i
ex E36 320 M50B20TU 93
man kalboj rodo D:00 ar kazka tokio, tipo nera kitokios, ar kaip ja pakeist? db doitclendu yra.
StandartinėParašytas: 29 Kov 2012, 18:26
auBi A6 2.5tdi+chip
ex E38 740i
pades kas?
StandartinėParašytas: 07 Bal 2012, 13:32
ex-E32 730i M30B30
ex-E32 730i M30B35
E38 730i M60B30
marko---
Na forume apie tai kalbeta buvo , kiek pamenu rase lyg kad per ta testa tik paziuret gali o kalba tik priejungus prie kompo pasikeist galima.. Jai neklystu :roll:
StandartinėParašytas: 07 Bal 2012, 17:20
auBi A6 2.5tdi+chip
ex E38 740i
MarcoE32 rašė:
o db aiskiau, dekui :)
StandartinėParašytas: 07 Bal 2012, 18:14
bmw e90 320d 06m
ex:bmw E39 525d 02m
ex:bmw E39 523i 98m
gal kas nufilmave turit niekaip neina padaryt kad vaziuojant roditu :(
StandartinėParašytas: 07 Bal 2012, 21:31
Kuri navigacija pas tave? MK kuris?
StandartinėParašytas: 07 Bal 2012, 23:26
bmw e90 320d 06m
ex:bmw E39 525d 02m
ex:bmw E39 523i 98m
Kancmanas rašė:
man rodos mk3 nes dvd uzraso nera
