Dabar yra 10 Kov 2026, 05:44
StandartinėParašytas: 21 Gru 2012, 10:54
E90 320D N47 - 130kW '08
F11 520d lci '14
AndriusDarling rašė:
neseniai pasikeiciau nauja akumuliatoriu bet del visa ko turiu klausima. Pas mane 2006m automatas uzvedimas per mygtuka Start/Stop. Ka daryti jeigu ziema nuo salciu neuzsives ? Mechanine patrauki pora metru su kita masina ir vsio o ka su sita daryt ? Ir prie to pacio kaip pasildyti pakaitinimo zvakes ? tiesiog degima pora kartu ijungti ir viskas ir iskarto uzvedineti taip?
Special starting conditions
In the following situations, press the accelerator
pedal halfway down when starting the engine:
>If the engine does not start on the first
attempt, for instance when it is extremely
hot or cold.
>If the engine is started at very low tempera-tures, below approx. + 57/–156, at high
altitudes above approx. 3,300 ft/1,000 m.
Avoid frequent starting in quick succes-sion or repeated start attempts in which
the engine does not start.Otherwise, the fuel is
not burned or inadequately burned and there is
a danger of overheating and damaging the cat-alytic converter.<
Cia taip rasoma manuale kaip reikia kurt prie specialu oro salygu (esant ypac saltam orui ar kalnuose). Turi iki puses nuspaust gazo pedala ir kuri masina tai vadima starting in quick succession. Taciau tuo piknaudziauti is pirmo karto neuzkurus nepatartina. :)
StandartinėParašytas: 03 Sau 2013, 21:16
E36 328 cabrio 96'
ex E46 330xd M53N 04'
ex E91 320d M47N2 05'
ex E34 525T M50 91'
ex E28 520 M20 87'
genadijus74
neseniai pasikeiciau nauja akumuliatoriu bet del visa ko turiu klausima...
E90 po akumo pakeitimo reikia atlikti akumo registracija, kad jo nesugadinti. Atlikai?
Gena
StandartinėParašytas: 09 Sau 2013, 12:34
EX: E30 324d M21 86'
EX: E36 318i M40 90'
EX: E36 325tds M51 99'
EX: E36 318is M42 95'
EX: E91 320d M47/T2 06'
EX: E39 530d M57 03'
EX: E46 323Ci M52 99'
E46 330Ci M54 01'
F25 x28i N20 17'
Genadijus (Gena) rašė:
Idomu, gal galima placiau?
StandartinėParašytas: 09 Sau 2013, 20:51
E36 328 cabrio 96'
ex E34 525T M50 91'
ex E28 520 M20 87'
genadijus74
Kywon rašė:
http://www.bimmerfest.com/forums/showth ... p?t=418907
Cia gali pasiskaityti... jei neregistruoji, tai trumpini akumo gyvenima, o jei įdejai ne ta, kaip priklauso, tai gali ir sprogti bagažineje. Kai pirkau E91, tai nežinojau koks akuumas priklauso, buvo įdėtas ne tas, tai per metus numiro akuumas.
Gena
StandartinėParašytas: 10 Sau 2013, 10:46
Per metus dabar daugelis akumu numiršta, dar jei "pagelbėji" jam, tai visai neproblema.
StandartinėParašytas: 10 Sau 2013, 11:06
E46 330Ci M54 01'
F25 x28i N20 17'
http://www.bimmerfest.com/forums/showthread.php?t=418907
Pries pora ar tris menesius keiciau akuma ir jau dabar pora dienu pastovejus sunkiau suka starteri. Manau, kad cia realus variantas su tuo registravimu. Ar pats vezei pas dyleri tai procedurai, ar galima pas kompiuteristus tai atlikt?
StandartinėParašytas: 10 Sau 2013, 11:28
[ex] e90 325d M57 '06
Kywon rašė:
Pakol prisiruosi uzregistruoti akuma- atjungi IBS sensoriu, du laidus (is minusinio iseina dar du laideliai, vienas su maza fiske, kitas su didesne). Abu atjungus, kraus 14/14.01v, kaip ir iprasta automobiliuose be sito sensorio. Na, o akumo registracija/duomenu atnaujinima gali atlikti kas turi atitinkama laida ir programa.
StandartinėParašytas: 16 Sau 2013, 20:40
E36 328 cabrio 96'
ex E34 525T M50 91'
ex E28 520 M20 87'
genadijus74
turiu INPA, tai pats atlikau veiksmą
Gena
StandartinėParašytas: 17 Sau 2013, 10:12
e90post skaiciau tema neperseniausiai, vienas bachurelis nepriregistravo akumo po pakeitimo, tai neuzilgo sis sprogo jo bagazineje...
StandartinėParašytas: 18 Sau 2013, 11:52
Drammen, Norway
BMW 17 i3 60ag
BMW 12 E70 3.0d
ex BMW 05 E90 320i
ex BMW 98 E39 528iA
Na nzn, as neregistravau to akumo, nes kai nusipirkau auto nezinojau, kad reikia priristi ji. Pasikeiciau pats, permeciau ir viskas. Jau pusantru metu kaip norma, ir kuriasi puikiai ir niekas nesprogo :wink:
Nesakau, kad nereikia, taciau as nepririsinejau ir nieko.
StandartinėParašytas: 27 Sau 2013, 12:23
VILNIUS
E90
As irgi nepririsinejau nieko ir prie salciu viskas normaliai dar pasildau zvakes truputi ir uzsikuria :) bet idomus dalykas reiks apsiklausti Krastoj ar dar kur del platesnes info apie sita :)
StandartinėParašytas: 27 Geg 2013, 17:42
E90 325D
Pririsineti reikia jei keiti AGM i paprasta akuma arba atvirksciai.
StandartinėParašytas: 04 Bir 2013, 14:20
Ir vel risat jus tuos akumus taip šnekedami nelabia nutuokiat kas tai yra. Nes su akumu susija yra dvi funkcijos.
