Dabar yra 21 Bal 2026, 07:49
Naujos temos kūrimas Atsakyti į temą  [ 82 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3, 4, 5, 6  Kitas
StandartinėParašytas: 01 Spa 2013, 16:34
Viena, Austrija
E61 530D LCI A-Sport M-Package
ex E34 M50B25 '90
Pasiskaitinėjau įvairiuose forumuose ir gamintojų puslapiuose apie antifrizus ir kokius galima naudoti, maišyti ir panašiai.
Gal kam bus aktualu, juk žiema ateina, sugalvos kas keistis...
Yra trys pagrindiniai antifrizų tipai (ne, tai ne G11, G12 ar G12+ ir tai ne kokybės požymis, tai tik VAG specifikacija pagal sudėtį):
IAT (Inorganic Additive Technology) - Conventional - Green/Yellow antifreeze contains silicates, phosphates and / or borates as corrosion inhibitors to keep the solution alkaline.
OAT (Organic Acid Technology) is usually dyed orange to distinguish it from other types of antifreeze. The coolant contains a totally different kind of additive package called Organic Acid Technology. The OAT corrosion in hibitors are slower acting and provide protection over a longer period of time.
OAT includes such ingredients as sebacate (Toyota & Honda), 2-ethylhexanoic acid (2-EHA) and other organic acids, but no silicates or phosphates (except in the case of Toyota's pink extended-life coolant, which adds a dose of phosphate to its extended-life OAT-based antifreeze). Organic inhibitors do not deplete as quickly as the inorganic inhibitors used in conventional coolants.
VAG G12 yra šios kategorijos antifrizas.
HOAT (Hybrid Organic Acid Technology) antifreeze is usually dyed yellow but may also be dyed orange or green. The package would compromise both inorganic and organic based additives. HOAT coolants are currently used by Ford, Chrysler, Mercedes, BMW and Volvo. The additive package in a HOAT formula coolant also contains silicates for added aluminum protection.
dar yra NOAT (Nitrite Organic Acid Technology - This type of extended life inhibitor package comprises carboxylic acids and derivatives in addition to nitrite, making it suitable for heavy duty applications) ir kitų tipų.
Bėda ta, kad mūsuose ant pakuočių nenurodo nei IAT, OAT, nei HOAT.
BMW rekomenduoja pilti hibridinį skystį su silikatais (HOAT) dėl tam tikrų dalių apsaugos, tad OAT (populiarusis G12 arba TL 774-D) netinka (daug kur radau parašyta, kad OAT maišyti apskritai draudžiama). VAG G11 arba TL 774-C yra su silikatais, kaip ir būtų galima pilti, tačiau čia reikia žiūrėti ar antifrizas turi BMW approval - BMW N 600 69.0.
Skirtumas tarp IAT ir HOAT yra tas, kad pridėti priedai į IAT (silicio junginiai) padaro aušinimo skystį neilgalaikį (dėl cheminių reakcijų), t.y. iki 2 metų, kai tuo tarpu HOAT gali būti iki 5 metų.
Pirkdami lietuvišką aušinimo skystį atkreipkite dėmesį, kad jie dažniausiai žymimi G11 ir G12, tačiau ant pakuočių nėra jokių specifikacijos atitikimų. Tad kas juose per priedai ir kokiu pagrindu padaryti, gali spėlioti tik turėdamas magišką rutulį.
kiek kainuoja OEM BMW skystis nežinau, tačiau iš ne OEM HOAT aušnimo skysčių, kurių manau galima lengvai gauti Lietuvoje, tinka:
Castrol Radicool (ANTI-FREEZE) NF
Addinol Antifreeze Super
BASF G48
Mobil™ Antifreeze Extra
Taigi gal kam bus naudinga
StandartinėParašytas: 01 Spa 2013, 18:04
ačiū tikrai naudinga info, sutaupiai musu laiko.
Dar reiktu rekomendaciju kur pirkti.
Paskutinį kartą redagavo Darenasp 01 Spa 2013, 19:12. Iš viso redaguota 1 kartą.
StandartinėParašytas: 01 Spa 2013, 18:15
airija
e60 525d m-sport 2005,10
ex. e 39 525d
ex.E34 525tds
Prie tepalu keitimo žadu ir aušinimo skysti pakeisti. Kiek pilasi i sistema? 2.5d motoras
StandartinėParašytas: 01 Spa 2013, 20:39
Viena, Austrija
ex E34 M50B25 '90
Visada kiekius tikrinu čia:
http://www.mobiloil.de/Germany-German-L ... h-oil.aspx
http://www.castrol.com/castrol/sectionb ... Id=7074725
http://www.omv.com/portal/01/com/omv/OM ... Oil_Finder
StandartinėParašytas: 03 Spa 2013, 19:02
Plungė
BMW E60 530D M Sport
ačiū Renis uz traktata. Tai mku dabar daryti as susipyliau Turtle kazkoki g12+ nemaciau daugiau jokio markiravimo, nejaugi keisti reiks?
StandartinėParašytas: 04 Spa 2013, 13:33
kupiskis
e90 335d 08 M sport
pvz. elites g12 su pliusu mano nuomone stipriausias antifrizas jis neverda net prie 120c.mes ji naudojam net britvom jis vienintelis atitinka pvz.temperaturinem savybem.o pompa tepancias nuo putojimo ir antioksidacines priemaisas dabar turi visi antifrizai mano visos auto su g12 ir ne vieni metai ir jokiu bugu.o tosolas manau traktoriams kur blokai spiziniai radijatoriai zalvariniai nes aliumini eda
StandartinėParašytas: 04 Spa 2013, 14:12
E64 M6
G32 630xd
ŠKODA ENYAQ
GAZ 22
Kaip ir visur yra gamintojai ir yra makaluotojai. Vieni sudeda penkis reikalingiausius priedus, kiti deda penkiasdešimt ir daugiau...
http://www.danushis.lt/lt/Produktai.html?article=2& iš šitų niekada gyvenime nepirkčiau... šiaip reikia žiurėti į aprašymus ir produkto kaina rinkoje, nes stebūklų nebūna ir pigiausias produktas ne bereikalo būna pigus... :wink:
Bardahl alyvos ir tepalai
StandartinėParašytas: 05 Spa 2013, 00:54
Mindaugas T rašė:
Sena taisykle, durnius ir ubagas x2 moka...
StandartinėParašytas: 05 Spa 2013, 08:36
F06 640i
Elite antifryza gamina Autochemija, kalbejau su jais, tai jie pati koncentrata perka Texaco G12 ir maiso pas save su distiliuotu.
StandartinėParašytas: 05 Spa 2013, 10:20
Viena, Austrija
ex E34 M50B25 '90
Ciakas rašė:
o G11 irgi daro iš G12? Labai gali būti, nes pas juos G11 irgi nėra silikatų :)
Lietuvišką antifrizą pilčiau nebent į namo šildymo sistemą, nes kartais keistai atrodo, kai lietuviški antifrizai turi VISŲ automobilių gamintojų patvirtinimus. Įdomu ar tie mašinų gamintijai apskritai žino apie tokių antifrizų egzistavimą :) Kartais net didieji antifrizų gamintojai OEM patvirtinimų neturi, kiek jų yra pas LT gamintojus.
StandartinėParašytas: 05 Spa 2013, 11:41
Ex E36 318i, Ex E46 328ci Mpak
now e61 530d Mpak
Darenasp rašė:
Auto E61, 530D, 2006m.
Koki pilti (jei ne OEM) ausinimo skysti?
Reikia paprasciausiai dapilti, dabartinio spalva lik ir melyna, o gal zalia, nes labiausiai pilka. :)
Kokia OEM ausinimo skyscio spalva turetu buti siame auto?
Ar galima maisyti pvz zalia su melynu? (kiek girdejau su raudonu negerai maisyti)
Ar siaip jau, pagal skoni?
ačiū.
Vokiskas ALPINE C11 (melynas) 5Ltr koncentratas Tanagroje su omni Id kortele apie 50lt +5ltr vandens dist. ir viskas gauni 10 ltr vokeciu kokybes skyščio. -36C TURI BUTI MELINAS i krasta paskambink.
StandartinėParašytas: 07 Spa 2013, 14:29
airija
ex. e 39 525d
ex.E34 525tds
zadu pirkti is INSAID Aušinimo Skystis FEBI KONCENTRATAS -80C 1,5L AKCIJA!
Gamintojas: FEBI (Vokietija). jie akcentuoja tas pats kas originalas tik ne BMW pakuotėje. gal kas esat pirke? kokie komentarai butu?
StandartinėParašytas: 07 Spa 2013, 14:54
E30 tc-baur cabrio
E36 325
chrysler sebring cabrio
toyota celica cabrio
E36 328 cabrio
bmw e61
grand voyager 3.3
w220 320cdi
Bmw m3 E36
bmw 325 cabrio E30
Bmw 535d e60
Bmw 535d f10
armis321 rašė:
pirk bet jei nepataikysi ir bus per mazai silikatu tai perkais ir uzkals motoras...
StandartinėParašytas: 07 Spa 2013, 15:14
airija
ex. e 39 525d
ex.E34 525tds
vytas85 rašė:
tu cia rimtai? ar gali jie taip stumti kad tas pats kas originalas tik ne bmw pakuotėje? ziurejau krasta koncentras supilstitas i 1,5l tara kaip ir FEBI. noriu susipirkti viska per intika nes uz 2av. grystu i lt masina iškarto i serviza nelabai noriu po parduotuves lakstyti laiko gaila :D :D :D
StandartinėParašytas: 07 Spa 2013, 17:22
E30 tc-baur cabrio
E36 325
E36 328 cabrio
bmw e61
grand voyager 3.3
w220 320cdi
Bmw m3 E36
bmw 325 cabrio E30
Bmw 535d e60
Bmw 535d f10
armis321 rašė:
aisku kad juokauju :wink: paprasciausiai juokinga kai zmones prisigalvoja tiek bedu lygioje vietoje...perki geresnes firmos antifriza pili ir galvos nesuki,as garantuoju netgi supylus ta lietuviska tu vaziuosi simta metu ir jokios bedos neturesi susijusios su tuo antifrizu.
