Dabar yra 22 Bal 2026, 00:57
Naujos temos kūrimas Atsakyti į temą  [ 1895 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 16, 17, 18, 19, 20, 21, 22 ... 127  Kitas
StandartinėParašytas: 28 Vas 2012, 19:28
E39 525dA'02
Ex E39 530dA'01
Ex E46 330d'01
naudoju INPA / Ediabas K+DCAN USB laida, irasiau viska pagal instrukcija ir paleidus bet koki testa kodel ismeta sita errora:??? batery ON ignition OFF rodo
beje, ar pajungus prie kompo laida lempute pastoviai turi degti?
StandartinėParašytas: 28 Vas 2012, 20:01
E36 318is sedan
E39 530d "Shadow Line"
lempute dega prijungus prie masinos
StandartinėParašytas: 28 Vas 2012, 23:07
Opel Vectra GTS 2.2 '03
ex.E38 - 728i '96
tomaszvalgas
L1F3
Inpa 5.03.
Pasijungiu prie mašinos, pas mane E38 3.0d.
Degimą rodo, akumą rodo, bet nieko daryt neleidžia.
Jungtis apvali po kapotų, kitos nėra.
Kai bandau klaidas nuskaityt, errorą meta, kad neprieina prie modulio ir visais kitais atvejais meta tą patį errorą.
Gali būt, kad mašina per sena ir nieko neišeis su Inpa?
Kabelio aprašymas:
Kodas:
BMW  USB to OBD Ignition Detection Diagnostics Data Cable
This cable will work on BMW cars using both K Line protocols, that's all BMW cars built before march 2007 when BMW changed the way the information was read from there vehicles from K-Line to D-Can, Our cable uses the latest FTDI chipset with the FT232BL controller IC and has TRUE ignition sense detection circuit built within the cable head allowing auto detection of ignition on/off cycles necessary for some coding/programming functions, Our USB-OBD Data cable eliminates the need to use a USB to Serial converter and is an all in one solution that requires no more hardware to use other that the cable and computer, no need for diagnostic heads of any kind, our cables are fully tested before we send them out and come complete with all the necessary drivers for installation so you have peace of mind knowing all you need comes complete with the cable.
Along with the cable you will receive full comprehensive step by step pictorial installation instructions to aid you in your installation as well as support should you need it , Our cable works with ALL versions of Windows Including both Windows Vista & Windows 7 32 & 64bit Versions
StandartinėParašytas: 29 Vas 2012, 00:12
Prie kitu masinu galit prisijungti? Jei taip ieskokit problemos masinoje. TDX laida tikrint pirmoje vietoje.
StandartinėParašytas: 29 Vas 2012, 03:04
pacioj inpoj yra dauguma erroru aprasimas.
c/ediabas/doku/faq
StandartinėParašytas: 29 Vas 2012, 19:13
ex.E38 - 728i '96
tomaszvalgas
L1F3
Kodas:
19
IFH-0009: NO RESPONSE FROM CONTROLUNIT
EDIABAS_IFH_0009
Meaning:
The ECU is not connected or does not respond.
Causes:
The ECU is not connected (or not properly).
The ECU is not supplied with voltage.
The ECU is addressed with a wrong address.
The ECU parameters are incorrect (concept, times, etc.).
Error correction:
Check the error causes above.
Target system:
WIN SCO QNX
Būtent šį errorą man meta kai pasirenku Engine ir M57... Bet kažkaip man nieko šitas aprašymas nesako.
Arunas B rašė:
Nebandžiau su kitom mašinom, neturi niekas iš pažįstamų nieko naujesnio negu E36.
StandartinėParašytas: 02 Kov 2012, 02:26
Youtubas visagalis sitame reikale. Kaip tik niurkiausi paskutines dvi dienas su visais instalais i nauja kompa, tai visus atsakymus rasit Youtube.
http://www.youtube.com/watch?v=dzPUxafEJ28
http://www.youtube.com/results?search_q ... 03l11l11l0
StandartinėParašytas: 06 Kov 2012, 22:46
Sveiki, gal galit pasidalinti failiuku: E39.ENG . Svarus instalas INPA 5.02 veikiantis, bet truksta E39 failiuko. ačiū
StandartinėParašytas: 07 Kov 2012, 09:22
E38 740i 94'
pasidaryk iš BMW_ALT.ENG, išmesdamas ko nereikia.
StandartinėParašytas: 07 Kov 2012, 14:22
Jau radau. Jei kam ateity reikes - pridedu E39 ir E36 eng failiukus.
CFGDAT.rar [5.67 KiB]
Atsisiųsta 1958 kartus(ų)
StandartinėParašytas: 07 Kov 2012, 15:16
toks klausimas - kam jie?
StandartinėParašytas: 08 Kov 2012, 16:02
DmK rašė:
Kai instaliuoji svieziai naujesne inpa, ne visada buna sie failiukai. Pas mane pavyzdziui ju nebuvo. Del to negalejau pasijungti prie E39, E36 ir E38 .
StandartinėParašytas: 08 Kov 2012, 16:32
pas mane ju nera, bet prie savo E39 prisijungiu. shift+f9 ir turi E36, E38, E39. todel ir paklausiau, ar reikalngi jie man.
StandartinėParašytas: 08 Kov 2012, 20:54
Pas mane mete klaidas, kol ju neikeliau. O dabar viskas OK :)
StandartinėParašytas: 08 Kov 2012, 20:59
as cia buvau pagalvojes jei modifikuoti "inpa configuration settings" (ten pat guli), pakeisti vietoj mini (ar kokio kito modelio) i E39, tai gal butu iskart ant ekrano ir nereiketu shift+f9 spausti?
