Dabar yra 22 Bal 2026, 20:30
Naujos temos kūrimas Atsakyti į temą  [ 169 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 6, 7, 8, 9, 10, 11, 12  Kitas
StandartinėParašytas: 28 Vas 2009, 13:58
Ot tinginiai... Google jums pades siuo klaisumu.. :wink:
OBC:
• Turn ignition to pos. II
• Push right button in the instrument cluster and keep it pushed. You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
• Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits together and write down that number, you will need it for unlocking all the functions. Example: DG23278 will lead to 2+3+2+7+8 = 22
• Push the right button until you see "Test Nr.19"
• Push left button until you see the number that is equal to the one you calculated above
• Push right button again
Navi:
* Push the "MENU" button to enter the main menu
* Scroll to the "SETTINGS" menu selection and click the knob to select it
* Push and hold the "MENU" button for about 10 seconds to enter the GPS Service Menu
Radio (su navi) (iki 09.2001):
1. Turn the radio on.
2. Within 8 seconds, press the 'INFO' button.
3. From the Info screen, select RDS (choose PTY on E38).
4. Press and hold the BM control knob (right side knob) for at least 8 seconds.
5. Scroll through functions using the station search buttons "< >".
6. Turn the radio off to leave the service mode.
Beje, ten radijai yra labai daug visokiu skirtingu variantu priklausomai nuo metu, navi buvimo/nebuvimo ir masinos modelio... :)
StandartinėParašytas: 28 Vas 2009, 21:54
JEEP, e23, e93 lci
Pas mane tas info mygtukas isvis nieko nedaro :roll:
StandartinėParašytas: 01 Kov 2009, 01:09
Xolen rašė:
Jo, pas mane Info ir Select irgi neveikia. Kazkur skaiciau ko reikia kad veiktu, ar tai radija pakeist i naujesne, ar tai MKIV isidet.. Nepamenu tiksliai, reikia ieskoti info internete.
StandartinėParašytas: 02 Kov 2009, 11:02
E39 525 tds 98'
E39 540 i
E46 320d
E 63 650i
duzis rašė:
pas manes vapshe 800k.km rodo
papasakosiu tokia liudna tiesa pries du metus buvau iskomandiruotas i italija ir ten is tos firmos direktoriaus (pas ji gyvenau) parsivariau 95m.540 zodziu rida buvo 140000 tikra salonas kaip naujas ir tt.turejau kaip antra masina metus pramogai bet atejo laikas kai viskas pradejo gesti t.y . amortizatoriai guoliai pakaba termostatas a/c kopresorius jis iki tol nieko nebuvo dares viskas buvo originalu tai va teko ji parduot nes tos smagios akimirkos pasidare ispudingai brangios dabar vazineju su 98 tds rida taipogi tikra pirkau dauzta 420000 jokiu gedimu neturejau pravaziaves jau virs 100000 tai va nuo to laiko tikrai nebijau dideles ridos
StandartinėParašytas: 03 Kov 2009, 00:40
Klaipeda
BMW E39 2.5TDS 1998m.
Rough_soul
o kas is to, kad jus suzinosit ta tikra kilometraza? pulsit pardavineti masinas??? :) vaziuoja, negenda ir viskas gerai. Tai gi ne nuliovas masinas perkam. Turejau as honda dizelini ir buvo ten 340000 ir viskas ok buvo... :) bimbaliuka savo net nenoriu tikrinti.
StandartinėParašytas: 03 Kov 2009, 17:59
E39 523i 1997m
523l E39 pas mane.Kaip minejot ispaudos ridos migtuka ir pasukiojus degima ties skaicium 2.0 visos rodikles pradeda judet ir uzsidega visas prietaisu skidelis.O paspaudinejus toliau ridos migtuka skaicia kaitaliojasi vietoj realios ridos kur buna.kas per skaicia ten prie tam tikru paspaudinejimu.gal kur yra paaikinta?
StandartinėParašytas: 05 Kov 2009, 13:07
E39 523i 98`
M52B25, Steptronic
justezas rašė:
tu realios ridos per tas funkcijas nepamatysi!!!! o kokios ten funkcijos, tai per paieska paieskok, tikrai ne karta sneketa buvo apie tai, kas ka reiskia.
StandartinėParašytas: 05 Kov 2009, 13:29
gali rida but ir 100k bet auto jau bus pavargus, čia kaip automatines greiciu dezes, vieniems jau 2003m masinoms pareina kitiems 98m dar veikia. daugiausiai priklauso nuo vairuotojo kiek laikys visi egragatai :}
StandartinėParašytas: 05 Kov 2009, 13:35
JEEP, e23, e93 lci
kad po 100k masina atrodytu pavargus, ja reik specelei lauzyt.
StandartinėParašytas: 06 Kov 2009, 11:38
E39 523i 1997m
jai labai nesupiksi prasyciau linka nukopinti kur apie tai kalbeta.dekui didelis ;]
StandartinėParašytas: 06 Kov 2009, 12:04
E39 523i 98`
M52B25, Steptronic
justezas rašė:
juk auksciau sio lapo angelas viska aprases ka daryti reikia (EN kalba), dar pridedu nuoroda http://www.ideaphile.com/bmw/540-obc.html
StandartinėParašytas: 06 Kov 2009, 16:01
E39 523i 1997m
didelis dekui
StandartinėParašytas: 06 Kov 2009, 16:18
e90 3.0d LCI M
ex. E46 2.0d
Alexander rašė:
Jei būtų galima patikrinti ar rida tikra, tai labai praverstų perkant mašiną. Bent jau man :)
My car isn't smoking, it's marking its territory.
StandartinėParašytas: 06 Kov 2009, 16:21
E39 523i 98`
M52B25, Steptronic
dalinai gali patikrinti prisijunges carsofta, scanneri.
StandartinėParašytas: 15 Bal 2009, 15:41
E34 525ix 141kw - 92
E39 530d 142kw - 02
E60 530d 160kw - 03
Ieskau kito Bmw...
E46 bandziau ridos skaiciukai pasikeicia, bet vietoj pirmo skaiciuko rodo - bruksniuka.
