Dabar yra 16 Sau 2026, 08:15
Naujos temos kūrimas Atsakyti į temą  [ 45 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3
StandartinėParašytas: 31 Sau 2009, 09:23
bmw e61,530,E39 525d
programiskai jokiu bedu...
StandartinėParašytas: 02 Vas 2009, 17:01
nulauziau savo tv pagal sita
Watch TV / Videotext during driving
This works on all 5/7 Series with the Mk. I Navigation System (the one with the male voice). On Mk II (the newer version with the female voice) you have to use "brightness" instead of contrast for TV and "color" instead of brightness for videotext to get the trick to work. I know that the trick works on latest 99 7series models as well. But I heard also that some cars sold into the US do not have any TV equipment on board. You will notice this as they do not have any TV option in the main menu. Also latest BMWs sold in Europe (2000 onward, 3/5/7 series) have the trick disabled! The only chance to get the TV running is somewhere hidden in the menu of the BMW Sevice Tester DIS. But up to now I can't thell you where. If I ever find it out, I'll post it here!
As far as I know the software update for latest navigation CD Roms does not affect or disable this trick.
Set ignition to pos. II
enter TV mode
enter "settings"
enter "contrast"
when the green contrast bar is visible, push the knob and keep it pressed
turn ignition off (keep button pressed!)
wait 8-10 seconds (timing must be accurate!)
release the knob
turn on ignition again
Now you can watch TV during driving (but always keep at least one eye on the road - that said)
To watch videotext use the same procesure as above, but chose"brightness" instead of "contrast"
pasirodo imanoma :) nors ir skaiciau forumus kad kas acinaujines navi iki naujausios versijos tai neveiks, bet man suveike ir sendien isbandziau vaziuojant ziuret, viskas good. pasmane mk2 jei ka, vietoi contrast naudojau brightness kaip ir raso, meginau kokius 3 kartus iseiles kad nereiktu bereikalo vedinet ir uzgesinet
StandartinėParašytas: 02 Vas 2009, 17:07
Tai kad ne nuo navi kompo priklauso atrakinimo budas (su mygtukais ar su kompu), o nuo video modulio. As va pas save pasikeiciau video moduli (berods 2003 ar 2004 metu isidejau) prie 16:9 monitoriuko, tai reikia naujai atrakint. Bet jau mygtuku maigymas nepades... :roll:
StandartinėParašytas: 02 Vas 2009, 17:20
o gal kas zino koki buda kaip galima butu aktivuoti "papildomas" nustatymu funkcijas? pas viena zmogu e39am lig ir MKI stovi, tv mazas, navigacija "kalba" vyriskai, kaip pas mane vienuzodziu. bet atidarius meniu punkta "SET" pas ji yra dar kelta papilodmu funkciju, tokiu kaip spalvos nustatymo, tipo zalia, melyna arba ruda ir dar kazkas. pas mane po defaultu stovi ruda ir niekaip negalima pakeisti :( , nera tokio meniu punkto... o taip noris melyno :?
StandartinėParašytas: 02 Vas 2009, 17:22
Tai cia man atrodo ar ne navi kompui reikia firmware atnaujint.. :roll:
StandartinėParašytas: 02 Vas 2009, 17:26
pasmane irgi yra nustatymas spalvu, treju rusiu, pries atnaujinant navi irgi buvo, navi mk2 moters balsas :)
StandartinėParašytas: 02 Vas 2009, 17:27
sanimda rašė:
Tai pas visus MKII buvo spalvu pasirinkimas. :wink:
StandartinėParašytas: 02 Vas 2009, 17:28
angelas_ rašė:
ech... tai skaityk niekad as to nepadarysiu :lol: , nes kazin ar kas Panevezy tokius dalykus daro...
StandartinėParašytas: 02 Vas 2009, 17:29
sickdog rašė:
Tai busi kada Kaune, duok zinia, atnaujinsim. Arba as kada gal iki Panevezio pas jumi i meeta i svecius atvaziuosiu. :wink:
StandartinėParašytas: 02 Vas 2009, 17:34
angelas_ rašė:
pasiulymas uzskaitytas =D> , tik va gali but geda savo bedanti rodyt :lol: , vis nesusitvarkau as ji iki galo :lol: :? .
o gal yra koks internet manualas tam reikalui ?
StandartinėParašytas: 02 Vas 2009, 17:36
sickdog rašė:
Taip, aisku kad yra. Pradziai siulau pasivartyti gren.ru puslapi. :)
StandartinėParašytas: 10 Vas 2009, 10:33
Plungė
egidukasv
sickdog rašė:
taigi pono angelo deka pasidariau softo atnaujinima =D> .
viskas parpasta, rakteli i antra pozicija, i navi sidiroma istatote softo CD. griztat i salona, is pradziu ekranas rodo nlb grazius vaizdus ir tai truputi gasdina, paskui uzsikrauna juodas fonas su bmw logo ir vyksta loadingas, apie 5 min +-, tada atsiranda uzras OK. paspaudus ji grizti i pagrindini meniu. viskas.
labai dziaugiuosi situo apdeitu, nes dabar pagaliau turiu MELINA meniu fona :twisted: =D> , nes rudas uzknises labai buvo(dar atsirado svesiai melinas ar pilkas atspalvis, neiziurejau dienos svesoje.. keista kad ne ZALIAS, nes pagal idejo turejo buti zalias..).
is maloniu smulkmenu dar atsirado day/night rezimas, ta prasme kol neijungtos sviesos rodo svesiai melinai ijungus sviesas viskas patamseja (skaityk night rezimas) ir geriau viskas matosi ir turbut nakti ne taip rezia aki. dar prisidejo nlb reikalinga funkcija kurios deka OBC gali vietoi temepraturos rodyti "arrival". pacioje navigacijoje irgi yra keleta smulkmenu nauju, pvz kai isvaziuoji i laukus atsiranda uzrasas kad sistema negali pateikti jokio marshruto nes tu kazkur grybauji (anksciau to nebuvo). balsas nepasikeite, vis tas pats dede Pranas aiskina kur sukti ir kur vaziuoti. na o daugiau nzn, gal dar kazka veliau pastebesiu.
Pas manes rodo kad yra MKII (SW 2-1/80) versija ir kiek perskaites pamaciau pastebejimus, kad dien/naktis ir navigacijoi uzrasai kad kazkur grybauni tai viskas jau yra beto kalba ne dedukas o bobute tad idomu ar imanoma ka nors naujo atrast jei atnaujinciau savo softa. Ir ar verta :!: :?:
StandartinėParašytas: 10 Vas 2009, 10:48
sunku pasakyti, jei nuo tavo turimos versijos iki naujausios yra daugiau nei vienas updeitas tai manau kad verta, gal istaisys kazkokias tau nematomas klaidas. o jei pas tave kokia priespaskutine tai kazin ar verta. is kitos puses updeitas uzima 10min.. taigi.
StandartinėParašytas: 10 Vas 2009, 10:51
neverta, jei paieskotum forumo paieskoi rastum linka kuriam parasyta nuo kokios versijos ten keiciasi ir pvz mk2 jei neklystu tereik 21 ar 26, o mk4 32lyg naujausia, irasius ja i mk2 niekas nepasikeis, nes is seno daikto neispausi daug navarotu vien tik su softu :)
StandartinėParašytas: 10 Vas 2009, 15:57
sickdog rašė:
Tai saunu =D> :wink:
P.S. Sakiau kad ten viskas paprasta.. Sunkumai prasideda kai "prisizaidziama".. :roll:
