Dabar yra 13 Bal 2026, 06:36
StandartinėParašytas: 05 Lie 2007, 20:16
gal kas nors gali papasakot kaip ten su tais daugikliais yra, pagal ka juos ten ivedineti ir t.t.
StandartinėParašytas: 05 Lie 2007, 22:31
E65 730d M57N
E60 530d M57N
Opel Astra H TwinTop
Kawasaki zx12r
Suzuki SV650
E39 540i M62 manual (ex)
E34 530i M60 manual (ex)
Yamaha YZF-R1 98m. (ex)
Mycius
If the OBC appears to be reporting inaccurate fuel consumption figures it can be calibrated to give the correct values. - Fill the fuel tank to the maximum and reset the trip counter and one of the OBC's average fuel consumption monitors. Run the fuel tank nearly empty and fill the fuel tank again to the maximum. The amount of fuel it now takes to fill the tank is the amount used to cover the distance recorded on the trip meter so, from this, work out the actual fuel consumption of the car and then compare this to what the OBC reported as the average fuel consumption. If these two average fuel consumption figures are not exactly the same then you need to calibrate the OBC by entering a new correction factor.
The fuel consumption correction factor is a locked function of the OBC so before you can access it, you must first unlock the OBC - Access the OBC test menu by simultaneously pressing the 1000 and 10 keys so that the display changes to "TEST". With the 10 & 1 keys enter 19 on the display and then press the S/R button. Add the current day and month (as it is known to the OBC) and enter this value and then press the S/R button, the OBC should now be unlocked. To access the fuel consumption calibration factor you once more need to simultaneously press the 1000 and 10 keys so that the display changes to "TEST". With the 10 & 1 keys enter 20 (Be careful not to enter 21 as this will reset the OBC) on the display and then press the S/R button - you should now see something like 1000 CORR, this is your current correction factor. To calculate your new correction factor use the following:
new_correction_factor = old_correction_factor * actual_mpg / obc_mpg
Enter your new correction factor into the OBC using the 1000/100/10/1 keys and then press the S/R button. If you want to relock the OBC - enter function 19 again then press the C/F button to lock.
p.s. is cia: http://www.bmwe34.net/E34main/Upgrade/OBC.htm
StandartinėParašytas: 15 Lie 2007, 16:18
[ex]bmw E34 525i 24V
Now: Superb 04 ; 1,9 TDI 96kw
gali paaiskinti lietuviskai kaip atlokinti as niekaip nesuprantu... :oops:
StandartinėParašytas: 15 Lie 2007, 16:29
Klubo Prezidentas
Klubo Prezidentas
Garažėlis
E28 528i ex
E28 524td crash
E28 M535i restoration
E30 318i ex
E32 730i ex
E36 318ti crash
E36 3**i sedan sport edition
E38 740i family car ex
F10 530DxDrive
Rolkis
http://www.bmw-klubas.lt/skaitykla.php? ... cijos.html
StandartinėParašytas: 15 Lie 2007, 19:32
Rolandas rašė:
http://www.bmw-klubas.lt/skaitykla.php?article=obcfunkcijos.html
ačiū jau taip bandziau ir vistiek tas lock nenusiema,,
StandartinėParašytas: 16 Lie 2007, 10:23
tai tada kazka ne taip padariai, nes pagal ta aprasyma labai graziai atsirakina
StandartinėParašytas: 16 Lie 2007, 15:26
svetimas rašė:
Butent as is kito galo suvedizau ta sudauginima,, ir neatsirakina o sian pameginau is kitos puses na is zmoniskos :D ir vuole :D
