Dabar yra 22 Kov 2026, 06:56
StandartinėParašytas: 14 Kov 2007, 09:43
vat klausimas jums brangieji kolegos:
kodel isidejus pilna OBC jis neveikia? net neuzsidega?
masina pas mane 525 su H.level pravodke, i OBC ateina kokie 20 laidu.
tiesa kai reikejo pilna OBC pajungti, tai truputi fiskiu vieta neatitiko pajungimo to el laikrodzio ir pilno OBC.
tai gal kas padet galit? kame ten problema? OBC is 535
StandartinėParašytas: 14 Kov 2007, 09:44
E64 M6
G32 630xd
ŠKODA ENYAQ
GAZ 22
Reikia is pin17 i pin9 paduot pliusa :wink:
StandartinėParašytas: 14 Kov 2007, 09:55
sakykit ponai, kaip tos pinus suskaiciuoti? nuo kurios puses?
StandartinėParašytas: 14 Kov 2007, 09:57
E64 M6
G32 630xd
ŠKODA ENYAQ
GAZ 22
Digital clock/temperature indicator
pin4: ground
pin5: blue/red/yellow, temp sensor
pin8: + from fuse F1
pin9: + from fuse F20
pin18: white/blue, chimes
pin19: white/red, chimes
pin22: grey/red, light switch
OBC
pin1: violet/green/yellow, alarm system
pin10: black/green, starter
pin6: + from fuse F17
pin9: + from fuse F20 (red/yellow)
pin25: yellow/red, turn signal switch
pin3: white/yellow, diagnostics
pin16: white/violet, diagnostics
pin14: white/grey, instrument cluster
pin7: black/white, instrument cluster
pin4: ground
pin20: black/red/yellow, pre-ventilation
pin21: black/white, pre-ventilation
pin23: violet/white/yellow, alarm system
pin17: red/grey/yellow, alarm system
pin26: black/red/yellow, fuel tank level sensor
pin12: brown/violet, fuel tank level sensor
pin11: white/black, DME
pin24: black/violet, DME
pin15: white/brown, radio
pin2: blue/brown/yellow, radio
http://www.bmwe34.net/e34main/upgrade/OBC.htm :wink:
StandartinėParašytas: 14 Kov 2007, 13:27
E36 316i M43 '98 Touring
E34 525i M50 '93
Kam skaiciuoti? Ten ant jungties viskas surasyta. Is krasciuku smulkiai parasyti skaiciai.
viewtopic.php?t=1497&postdays=0&postorder=asc&highlight=obc+pin+++pin&start=0
StandartinėParašytas: 15 Kov 2007, 08:49
Jonava
E70 X5, 07'
Transporter550
Afonia rašė:
Pažiūrėk iš galo turėtu būti lyg ir dvi lemputės. Jei jos perdegusios, tai nieko ekrane ir nematysi. OBC gali skaičius rodyti, bet jei lemputės nešviečia, tai tų skaičių ir nesimato.
StandartinėParašytas: 15 Kov 2007, 15:01
E46 320 M47 2001
klysti, ten is viso yra trys lemputes. dvi is virsaus, viena is apacios. pas mane buvo perdegusios ir is arti tikrai visi skaiciai matydavosi.
StandartinėParašytas: 17 Kov 2007, 14:15
ačiū visiems kolegos. laideliu sujungimas padejo. sekanti savaitgali bandysiu det rankenele posukiu :)
