Dabar yra 10 Kov 2026, 07:26
StandartinėParašytas: 08 Vas 2013, 14:43
G01 X3 B48 19'
E90 335i N54 07'
F34 335ix N55 14'
E90 325i N52 07' ex
E46 M3 S54 02' ex
gal kas būsite susidūrę su tokia problema: atliekant serviso inspekcijas yra nustatomas kilometražas ir/arba data sekančiai inspekcijai. Man atėjo laikas keisti microfilter, tai padariau pats labai nesudėtingai, tačiau per borto kompą neleidžia pakeisti sekančios inspekcijos datos ir pastoviai tik užvedus kokią minutę dega raudona "service" indikacija.
Gal žinote kaip galima "nunulinti" šitą reikalą t.y. pakeisti sekančios inspekcijos datą? Turiu OBD kabelį ir INPA, bet ten nieko tokio nerandu... Kokie dar variantai? Kažkaip akis rėžia tie raudoni "service" signalai :)
StandartinėParašytas: 08 Vas 2013, 15:13
Pabandyk pagal sita instrukcija. Tikrai turetum apseit ir be inpa
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to disappear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
Average is failure
StandartinėParašytas: 10 Vas 2013, 13:01
G01 X3 B48 19'
E90 335i N54 07'
F34 335ix N55 14'
E90 325i N52 07' ex
E46 M3 S54 02' ex
Kaip ir rašiau viršuje, per borto kompą (tavo nurodytu metodu) microfilter "nuresetinti" kažkodėl neleidžia... Dėlto ir klausiu gal yra kažkoks kitas būdas.
StandartinėParašytas: 10 Vas 2013, 15:25
nerijjus rašė:
Nerijau :) taigi paimk ir privaziuok ;)
