| [E46] BC testai neisijungia https://forumai.bmw-klubas.lt/viewtopic.php?f=59&t=64981 |
| Autorius: | arwis21 [ 20 Bal 2009, 17:55 ] |
| Pranešimo tema: | [E46] BC testai neisijungia |
Automobilio, apie kuri norite paklausti Pagaminimo metai:1999 Variklis:1.8 Degalai:benzas Problema/klausimas: Kodel neveikia testai skydelyje(OBC rankeneles nera)? nei ant vieno is 21 testo nieko nerodo, tik ant 19 testo paraso OFF, ON ir taip mirkcioja ir niekaip neina ijungti, kame reikalas kas negerai? Ačiū! |
| Autorius: | rG [ 20 Bal 2009, 19:51 ] |
| Pranešimo tema: | Re: [E46] BC testai neisijungia |
viskas cia gerai, ant 19 testo turi ijungti ON, tada atsirakina visi kiti testai. Bet 2 testas turetu isijunugt ir be atrakinimo. |
| Autorius: | arwis21 [ 21 Bal 2009, 09:17 ] |
jo jo, vakar per youtube issiaiskinau |
| Autorius: | Amigo [ 21 Bal 2009, 17:18 ] |
BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test 4 testas momentines kuro sanaudos,5 testas vidutines kuro sanaudos... |
| Autorius: | arwis21 [ 21 Bal 2009, 18:20 ] |
o dekui
| Autorius: | xolera [ 30 Geg 2011, 14:23 ] |
o tai eina nustacius tam tikra funkcija pasilikt ja kad rodyt vaziuojant tarkim temperatura ar sanaudas? nes uzkurus vel isijungia kilometgrazas su laikrodziu ir vsio |
| Autorius: | eReg [ 31 Geg 2011, 15:21 ] |
Na taip tas tai beda, kad degima isjungus/ijungus vel is naujo viska reaguliuot reik |
| Autorius: | xolera [ 31 Geg 2011, 15:51 ] |
nzn as turbut lopas nes man tai ten nieko nerodo beje gal zinot kas rankeneles pririsa prie kompo? (kad veiktu BC nuo rankeneles) |
| Autorius: | eReg [ 01 Bir 2011, 16:47 ] |
Speju, kad rodo, tik kitas klausimas ar tu supranti ka ten rodo |
| Autorius: | xolera [ 01 Bir 2011, 17:16 ] |
19 funkcijoj spausdavau kai uzsiziebdavo on, dabar issiaiskinau kad reik spaust ant off |
| Autorius: | eReg [ 01 Bir 2011, 23:50 ] |
http://www.tavoauto.page.tl/BMW.htm "E46 BC rankenėlės prikodavimas" |
| Autorius: | xolera [ 02 Bir 2011, 13:58 ] |
dekui tau zmogau dar klausimas: prikodavus rankenele, duomenis rodo vietoj laikrodzio ar taip pat kaip ir per slaptas funkcijas vietoj kilometrazo? |
| Autorius: | eReg [ 02 Bir 2011, 14:54 ] |
Vietoj laikrodzio |
| Autorius: | artukss [ 29 Lie 2011, 10:15 ] |
Sveiki, Nekuriant naujos temos prie to pacio paklausiu. Gal zinote kas Siauliuose BC rankenėlės prikoduoja.? |
