Dabar yra 22 Bal 2026, 09:03
StandartinėParašytas: 20 Bal 2009, 17:55
E36 2.5d/105kw, E90 320d/130kw, F07 530d/190kw, F06 640d/230kw, G02 X4 30i/185kw
Pagaminimo metai:1999
Variklis:1.8
Degalai:benzas
Problema/klausimas: Kodel neveikia testai skydelyje(OBC rankeneles nera)? nei ant vieno is 21 testo nieko nerodo, tik ant 19 testo paraso OFF, ON ir taip mirkcioja ir niekaip neina ijungti, kame reikalas kas negerai? Ačiū!
StandartinėParašytas: 20 Bal 2009, 19:51
E39 525d
viskas cia gerai, ant 19 testo turi ijungti ON, tada atsirakina visi kiti testai. Bet 2 testas turetu isijunugt ir be atrakinimo.
StandartinėParašytas: 21 Bal 2009, 09:17
jo jo, vakar per youtube issiaiskinau :) o kuris pvz rodo kuro sanaudas 100km?
StandartinėParašytas: 21 Bal 2009, 17:18
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
4 testas momentines kuro sanaudos,5 testas vidutines kuro sanaudos...
Average is failure
StandartinėParašytas: 21 Bal 2009, 18:20
o dekui \:D/
StandartinėParašytas: 30 Geg 2011, 14:23
Marijampolė/Kaunas
E46 320D
o tai eina nustacius tam tikra funkcija pasilikt ja kad rodyt vaziuojant tarkim temperatura ar sanaudas? nes uzkurus vel isijungia kilometgrazas su laikrodziu ir vsio
StandartinėParašytas: 31 Geg 2011, 15:21
Ex - E46 318ci
E46 330D
eregasss
Na taip tas tai beda, kad degima isjungus/ijungus vel is naujo viska reaguliuot reik
CNC qube - CNC frezavimas, pjovimas: http://cnc.qube.lt
Studio qube - interneto svetainių kūrimas, 3d vizualizacijos ir modeliavimas http://www.qube.lt
StandartinėParašytas: 31 Geg 2011, 15:51
Marijampolė/Kaunas
E46 320D
nzn as turbut lopas nes man tai ten nieko nerodo :D eina vaiksciot po tas funkcijas, bet nerodo man ne temperaturos ne sanaudu, nieko..
beje gal zinot kas rankeneles pririsa prie kompo? (kad veiktu BC nuo rankeneles)
StandartinėParašytas: 01 Bir 2011, 16:47
Ex - E46 318ci
E46 330D
eregasss
Speju, kad rodo, tik kitas klausimas ar tu supranti ka ten rodo :)
StandartinėParašytas: 01 Bir 2011, 17:16
Marijampolė/Kaunas
E46 320D
19 funkcijoj spausdavau kai uzsiziebdavo on, dabar issiaiskinau kad reik spaust ant off :) tuoj eisiu ismegint, o gal zinot kas kaune rankenele priprogramuotu prie BC?
StandartinėParašytas: 01 Bir 2011, 23:50
Ex - E46 318ci
E46 330D
eregasss
http://www.tavoauto.page.tl/BMW.htm "E46 BC rankenėlės prikodavimas"
StandartinėParašytas: 02 Bir 2011, 13:58
Marijampolė/Kaunas
E46 320D
dekui tau zmogau :)
dar klausimas: prikodavus rankenele, duomenis rodo vietoj laikrodzio ar taip pat kaip ir per slaptas funkcijas vietoj kilometrazo?
StandartinėParašytas: 02 Bir 2011, 14:54
Ex - E46 318ci
E46 330D
eregasss
Vietoj laikrodzio :)
StandartinėParašytas: 29 Lie 2011, 10:15
ex E36 320i, E46 m47 320D
Nekuriant naujos temos prie to pacio paklausiu.
Gal zinote kas Siauliuose BC rankenėlės prikoduoja.?
