| [E46] Padangų slėgio kontrolė https://forumai.bmw-klubas.lt/viewtopic.php?f=59&t=35697 |
| Autorius: | Taspas [ 29 Lap 2007, 13:15 ] |
| Pranešimo tema: | [E46] Padangų slėgio kontrolė |
Koks padangų slėgio kontrolės (RDC) veikimo principas?
| Autorius: | runcikas [ 29 Lap 2007, 13:29 ] |
| Pranešimo tema: | |
turetu but vintiliuose dacikai, is kuriu ir gauna info tas modulis apie slegi. |
| Autorius: | Taspas [ 29 Lap 2007, 13:33 ] |
| Pranešimo tema: | |
runcikas rašė: turetu but vintiliuose dacikai, is kuriu ir gauna info tas modulis apie slegi. Nėra jokių daviklių, bet va radau straispnį... Cituoti: Wheel-Speed Based Pressure Sensing
The direct pressure sensing approach described above requires new hardware - the pressure sensors, receiving antennas, and display. So why not instead use sensors already in the majority of new cars - the wheel-speed sensors used in traction control and ABS applications? By using the wheel speed sensors to detect tyre-to-tyre differences in straight-line wheel speeds, an under-inflated wheel can be identified. This is because the rolling radius of the wheel will decrease with a drop in pressure, and so relative to the other wheels, it will rotate more quickly. <...> However, while an elegantly simply approach, it does have some major downsides. The wheel-speed based pressure sensing approach is used in the 2001 BMW M3 convertible and 750iL models. In the M3 owner's manual the following warnings are made: The system cannot alert you to severe and sudden tyre damage caused by external factors. The system will not identify the natural, even loss of pressure in all four tyres. Under certain circumstances, there may be false warnings or a delayed detection of losses in pressure when driving on snow-covered or slippery road surfaces. A sporty driving style (slip at the wheels receiving the torque, high lateral acceleration) can lead to delayed system warnings. |
| Autorius: | Ju|ius [ 29 Lap 2007, 14:41 ] |
| Pranešimo tema: | |
Jei trumpai, tai remiasi ABS'o dacikais ir jei pamato, kad vienas ratas pradeda greiciau suktis nei kiti, vadinasi sumazejo jo diametras ir padangoj truksta oro. |
| Autorius: | Tautietis [ 29 Lap 2007, 19:10 ] |
| Pranešimo tema: | |
Yra ir RDC sistema(su slegio davikliais ratuose ) ir yra RPA sitema (naujesne nuo 2003m kur remesi ABS davikliais ).Jeigu nera ratlankiuose davikliu ,tai arba ratlankiai ne orginalas,arba tiesiog pakeisti i ratlankius kurie neturi davikliu. |
| Autorius: | Germany [ 29 Lap 2007, 20:31 ] |
| Pranešimo tema: | |
pasmane yra ratuose tie davikliai, bet daznai jis acijungia. speju dacikus reik keist, skaiciau kazkur forume kainuoja apie 1000lt ir reikia keisti kas 5m (del kainos gerai nepamenu bet zinau kad nepigus) |
| Autorius: | Virgis [ 04 Gru 2007, 11:03 ] |
| Pranešimo tema: | |
Pas naujus XXXXXXXX automobilius stovi davikliai ratlankiuose (daviklis su ventiliu). Prie ratu, arkose stovi siustuvai/imtuvai, kurie siuncia signala davikliui ir is jo gauna atsakyma, kokis yra slegis. Dazniausiai saibom pareina davikliai, laidu jungtys. Patys siustuvai sugenda laaabai retai. O sistema, skaiciuojanti rato pakitimus nuo ABS sistemos, kazkokia nesamone man gaunasi. Visu pirma turi buti ziauriai tikslus griacio skaiciavimas. Po kablelio min. 3-4 skaiciai. Turi buti vairo padeties davikliai, apkrovu davikliai r pan, kad sistema neapsigautu ilguose posukiuose, uzkrovus tik viena automobilio puse. |
| Autorius: | Įtariu_BITES [ 04 Gru 2007, 17:41 ] |
| Pranešimo tema: | |
Virgis rašė: Pas naujus XXXXXXXX automobilius stovi davikliai ratlankiuose (daviklis su ventiliu). Prie ratu, arkose stovi siustuvai/imtuvai, kurie siuncia signala davikliui ir is jo gauna atsakyma, kokis yra slegis. Dazniausiai saibom pareina davikliai, laidu jungtys. Patys siustuvai sugenda laaabai retai.
O sistema, skaiciuojanti rato pakitimus nuo ABS sistemos, kazkokia nesamone man gaunasi. Visu pirma turi buti ziauriai tikslus griacio skaiciavimas. Po kablelio min. 3-4 skaiciai. Turi buti vairo padeties davikliai, apkrovu davikliai r pan, kad sistema neapsigautu ilguose posukiuose, uzkrovus tik viena automobilio puse. OT: jau matau perpektyva pacukams - sukinėti tokius ventylius lauk |
| Autorius: | Grill [ 04 Gru 2007, 22:52 ] |
| Pranešimo tema: | |
Įtariu_BITES rašė: OT: jau matau perpektyva pacukams - sukinėti tokius ventylius lauk Pacukai butu nesusiprate, o tu padejai suprasti |
| Autorius: | Tautietis [ 05 Gru 2007, 00:05 ] |
| Pranešimo tema: | |
Grill rašė: Įtariu_BITES rašė: OT: jau matau perpektyva pacukams - sukinėti tokius ventylius lauk :) Pacukai butu nesusiprate, o tu padejai suprasti :lol: Sakyciau reikia salinti sia minti, kol nepamate tas kam negalima :) |
| Autorius: | Virgis [ 05 Gru 2007, 09:20 ] |
| Pranešimo tema: | |
Tautietis rašė: Grill rašė: Įtariu_BITES rašė: OT: jau matau perpektyva pacukams - sukinėti tokius ventylius lauk Pacukai butu nesusiprate, o tu padejai suprasti Tikrai taip. Neismontavus padangos tu davikliu neimanoma isimti. O is isores jie labai nesiskiria nuo standartiniu, siek tiek patiuninguoti. O ir isidejus ta davikli i savo masina, naudos bus panasiai tiek, kiek is ozio pieno. Nes dar reikes siustuvo/imtuvo, proco informacijai apdirbt ir displejaus informacijai pateikt. |
| Autorius: | Įtariu_BITES [ 05 Gru 2007, 09:21 ] |
| Pranešimo tema: | |
Virgis rašė: Tikrai taip. Neismontavus padangos tu davikliu neimanoma isimti. O is isores jie labai nesiskiria nuo standartiniu, siek tiek patiuninguoti. O ir isidejus ta davikli i savo masina, naudos bus panasiai tiek, kiek is ozio pieno. Nes dar reikes siustuvo/imtuvo, proco informacijai apdirbt ir displejaus informacijai pateikt.
tai jau tikrai, pacukai laupydami mašiną masto apie tai kaip visa tai pritaikys savo golfui |
| Autorius: | GT999 [ 05 Gru 2007, 10:10 ] |
| Pranešimo tema: | |
Siaip jau Hella gamina toki komplekteli http://www.hella.com/produktion/HellaRe ... EN_HSG.pdf |
