Dabar yra 22 Bal 2026, 11:11
Naujos temos kūrimas Atsakyti į temą  [ 49 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3, 4
StandartinėParašytas: 22 Bal 2012, 13:02
Germany rašė:
prikelsiu sena tema ir paskutini klausima, kaip toki (harman kardon) stiprintuva pasijungti prie paprasto mago ir 10 HK koloneliu ?:)
jeigu gerai suprantu tai : i 5 reikia paduoti +12v, 26 kebulas, i 10 reikia +12v kad ijungti viska. o 30,29 ir 9,8 yra kaip line in ir nuo magiuko line out isejimu turi jungtis i stipr ?
situos laidus susijungti ir gros.
Grey ½ of connector
Pin # 13 / Tweeter Rear Right door + * Yellow Pin # 21 / Tweeter Rear Right door - *Blue / yellow
Pin # 12 / Tweeter Front Right - Blue / Brown Pin #20 / no connection
Pin # 11 / Tweeter Front Right + Blue / black Pin #19 / no connection
Pin # 10 / Switched +12v remote turn on White Pin #18 / no connection
Pin # 9 / Head unit output Front Right + Blue / red Pin #17 / Head unit output Front Right - Brown / orange
Pin # 8 / Head unit output Rear Right + Blue / black Pin #16 / Head unit output Rear Right - Brown / orange
Pin # 7 / no connection Pin #15 / no connection
Pin # 6 / no connection Pin #14 / no connection
Pin # 5 / +12v factory amp +12v supply *Red / green
Pin # 4 / Woofer Front Left +Blue / white
Pin # 3 / Woofer Front Left -Blue / brown
Pin # 2 / Woofer Rear Left +Yellow
Pin # 1 / Woofer Rear Left -Brown
Black ½ of connector
Pin # 34 / Tweeter Front Left - Yellow / brown Pin # 42 / Mid Front Right door + *Green
Pin # 33 / Tweeter Front Left + Yellow / red Pin #41 / Mid Front Right door - *Blue / green
Pin # 32 / Tweeter Rear left door - * Yellow / brown Pin #40 / Mid Front left door + *White
Pin # 31 / Tweeter Rear Left door + * Yellow / black Pin #39 / Mid Front left door - *Blue / white
Pin # 30 / Head output Front left - Brown / orange Pin #38 / Head output Front Left + Yellow / red
Pin # 29 / Head output Rear Left - Brown / orange Pin #37 / Head output Rear Left + Yellow / black
Pin # 28 / no connection Pin #36 / no connection
Pin # 27 / no connection Pin #35 / no connection
Pin # 26 / DC ground factory ampBrown
Pin # 25 / Woofer Rear Right +Blue
Pin # 24 / Woofer Rear Right -Brown
Pin # 23 / Woofer Front Right +Blue / Red
Pin # 22 / Woofer Front Right -Blue / Brown
StandartinėParašytas: 22 Bal 2012, 15:38
tai kaip supratau grinai nuo mago paprastu isejimu laidai jungiasi i stiprintuva tai yra vadinamus Head output, o jeigu pvz noreciau dar suba nuo atskiro stiprintuvo pasijungti tai reikes is vadinamu Head output jungti i kita stiprintuva tik dar dasipirkti ta dezute kur sumazina srove tai yra padaro is paprastu isejimu line-out ? aisku yra ir kitu varijantu pvz kiti stiprintuvai ir hi input turi ir t.t ? nu jeigu teisingai viska supratai tai dekui, galvojau bus sunkiau :} beto vienas neaiskumas fiskeje, seip netycia pastebejau. radau internete hk stiprintuvo fiskes foto, ir pvz pirmas pinas yra rudas antras geltonas, o pas mane atvirksciai, bei kitoi fiskutei 24 ir 25 taspats. likau nesuprates kodel taip. kiti laidai kiek ziurejau sutampa su googles info (ta prasme spalvos) aisku cia maza beda nes tai tik subo +/- gales istestuoti kaip geriau, tik idomu kodel taip yra..
StandartinėParašytas: 22 Bal 2012, 20:27
radau truputi tikslesne pinu shema http://forum.e46fanatics.com/showthread.php?t=824109 ir iskilo klausimas ka daryti su 15 ir 20 laidais, 20 tai kaip suprantu nesvarbu, o 15 kaip suprantu yra is garso jungiklio kuri junginejant keiciasi garsas http://www.youtube.com/watch?v=PvnEZJe6Neg pats perjungimas 2:17 idomu ka i ta laida paduoti, +12v ? truputi rizikinga testuoti tai gal kas tiksliau zino :)
arba gal kasnors is turinciu harman kardon sistema galetu pamatuoti to jungiklio vieno laido srove, konkreciai testerio pliusas prie geltonas/juodas laido, o minusas betkur i mase :}
StandartinėParašytas: 23 Bal 2012, 19:31
zodziu sendien ismeginau viska pajungti, tai likau patenkintas kad viskas taip paprastai susijunge ir kad geras kokybiskas garsas, bandziau i ta 15 pina paduoti 12v tai garsas truputi pritilo ir niekas nepasikeite, tai daugiau ir nemeginau, veliau dar ismeginsiu kaip sujungsiu viska masinoi, zodziu kaip ten bebutu garsas ispudingas, gal truksta zemu, bet kambary bandziau ir garsiakalbiai niekur nesumontuoti buvo tai gal del to ir truko, bet cia maza beda :)
