Dabar yra 22 Bal 2026, 14:55
Naujos temos kūrimas Atsakyti į temą  [ 116 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3, 4, 5, 6, 7, 8  Kitas
StandartinėParašytas: 17 Rgs 2009, 21:48
Vilnius, Panevežys
mindaugas.lukosius
Man vakar atsivedė laidus iki priekio iš bagažinės. Atjungta navigacija, ten pat užmauta fiškė ir atvesti laidai iki priekinės panelės. Kainavo ~190Lt. Liko įsigyti rėmelį iš lemonos ir bus baigta.
StandartinėParašytas: 22 Spa 2009, 02:43
E46 325ci
E36 318 Cabrio
E36 sedanas
siaip jaigu kas norit pasijungti kokia ipod ar pan prie originalaus mago yra jau dabar fishkes butent siai problemai su bmw. atjungi maga jungi prie laidu fishke.. tada is ten iseina laidai kuriuos jungi atgal prie mago ( kad galetum ir normaliai ir CD ir radio klausytis) ir is to pirmo pajungimo taip pat iseina laidas i maza stipriaka didzio nu gal kokia 7cm ant 7cm ir is stipriakelio iseina laidas telefonui ar ipod ar ka jus dar benoretumet jungtis. Pilna informacija:
iPod, MP3 Aux-in Amplified Interface Adapter
Works with ALL Portable devices with 3.5mm sockets
Our Aux interface is different to any other on the market at the moment, this is because it doesn't use the changer port on your CD player so you can keep your CD changer and use this interface as well.
FITTING:- Simply connect the factory stereo connectors into the aux-in amplified interface supplied, then connect the aux interface back into the stereo with the wiring harness supplied - thus making a loop, giving you an audio output for your iPod / portable MP3.
Also another feature that makes our aux interface more unique is when it is activated this amplified unit, when used in conjunction with a 3.5mm jack lead, mutes the audio system in the car and allows connection to any portable audio source (e.g. iPod /MP3 player etc).
Thus allowing you to access your favourite tunes through your standard factory -fitted unit but with a CLEARER MORE DEFINITIVE SOUND & INCREASED VOLUME FROM YOUR PORTABLE DEVICE.
Our interfaces will work with all ipods on the market at this moment in time.
Features:
* Multimedia Amplifier
* ISO connectors
* Soucre detection turn on
* Powers off 10 secs after source is turned off
* plug and play connection
* Use any media source with a 3.5mm headphone jack
This interface is ideal for the following audio devices
* MP3 Players
* iPods
* DVD players (audio only)
* Mobile Phones
* PDA
* Laptop
* And all devices with a 3.5mm jack socket
Compatibilty
* BMW 3 Series 1998 -2001
* BMW 5 Series 1996 - 2001
* BMW X5 2000 - 2001
* BMW 7 Series 1994 - 2003
* BMW Mini 2001 - 2002
kaina: 250lt mazdaug... bet man tai padejo isspresti problema savojoj masinoi be ardimu ir litavimu ir kitokiu nesamoniu.. jaigu kam reikia rasykit i Pm..:)
Tu tik nieko nesakyk!.. As ta S*ka pats uzmusiu! :D
StandartinėParašytas: 22 Spa 2009, 08:58
Vilnius, Panevežys
mindaugas.lukosius
Džiugu, kad už prieinamą kainą yra adapteris. O kaip skambesys? Man su alpine aftermarket magu, toks didelis skirtumas. Kolonkes keisti, mano poreikiams, praėjo visi norai. Ypač gerai skamba brit pop-rock dainos iš ipodo. (Liko subui susitaupyti).
Gal dėk skelbimą į skyrelį parduodu.
StandartinėParašytas: 03 Sau 2010, 11:58
E61 525d
Gal kas esate susidūrę ar yra galimybė nieko nelituojant programiškai nustatyti, kad magnetola veiktų neįjungus degimo. Magnetola originali. Žinau, kad nesudėtinga padaryti papildomai padavus maitinimą, bet norėčiau to išvengti.
Iš anksto dėkingas.
StandartinėParašytas: 03 Sau 2010, 13:47
sun-man rašė:
Iš anksto dėkingas.
Paspausk garso reguliavimo ratuka ir isijungs jis ir be degimo :D
Average is failure
StandartinėParašytas: 03 Sau 2010, 14:02
ex E46 330d
Golf Variant
2019 1.5TSI 130H DSG
Amigo rašė:
nu kas per atsakymas #-o žmogus nori įjungt radiją išvis be rakto, o tai padaryti galima tik perprogramavus, nes ir pas mane veikia tik su degimu, bet man tas nemaišo.
///M3
StandartinėParašytas: 03 Sau 2010, 14:13
rDx^ rašė:
Tai taip iseina pas mane perprogramuota nes veikia ir be rakto? o gal jus cia apie kasetini maga kalbat?
Average is failure
StandartinėParašytas: 03 Sau 2010, 14:21
E61 525d
Amigo rašė:
Paspaudus garso mygtuką neįsijungia.
StandartinėParašytas: 03 Sau 2010, 14:47
ex E46 330d
Golf Variant
sun-man rašė:
Sun-man koks magas pas tave ? kasete + CD-changer?
///M3
StandartinėParašytas: 03 Sau 2010, 15:19
E61 525d
rDx^ rašė:
Taip kasetė + CD changer.
StandartinėParašytas: 03 Sau 2010, 20:09
ex E46 330d
Golf Variant
sun-man rašė:
na ir pas mane. matyt jos tokios ir ėjo tik nuo rakto, bet viską galima manau lengvai perprogramuot, juk cia tik elektronika ;)
///M3
StandartinėParašytas: 03 Sau 2010, 21:21
E46 330xd. 02'
Pas mane magas su kasete orginalus, bet weikia ir be raktelio,reikia tik paspaust knopke ;)
StandartinėParašytas: 03 Sau 2010, 22:04
ex E46 330d
Golf Variant
Donatas20 rašė:
tai changer`io nėra? negalvokit, kad mes tokie buki ir nemokam knopkės paspaust ;D tiesiog taip padaryta vokietukų
///M3
StandartinėParašytas: 04 Sau 2010, 13:41
E46 330xd. 02'
ne,changerio nera :D
StandartinėParašytas: 04 Sau 2010, 16:50
E90 318d M47TU2 BiTurbo
ex E46 320d M47
ex E34 535i M30
ex E46 318i M43
sun-man rašė:
Iš anksto dėkingas.
Sveikas,
Nzn ar su orginaliu tas pats bet jungiant aftermarket maga paprasciausias variantas geltona laida einanti is mago jungi prie raudono (raudonas taip pat turi but savo vietoj, t.y. prie raudono.(kartais jie buna sukeisti vietom)).
