[E60] service engine soon indicator lamp
https://forumai.bmw-klubas.lt/viewtopic.php?f=53&t=92594
Puslapis 11
Autorius:  JONAS.... [ 14 Lap 2010, 11:42 ]
Pranešimo tema:  [E60] service engine soon indicator lamp
Pagaminimo metai:2004
Variklis:3.0
Degalai:d
Problema/klausimas:sveiki.pastebejau kad pas daugeli ijungus degima uzsidega si lempute o uzkurus uzgesta (service engine soon indicator lamp). bet mano auto ji ijungus degima nesijungia visai, ir uzkurus nedega. Kazin kokia jos paskirtis ir ar pas visus ji turi uzsidegt pries uzkuriant. pabandziau prietaisu skydeli atrakines padaryti testa tai ji uzsidega kuo puikiausiai per ta patikrinima. ačiū uz atsakymus
images.jpg [ 2.39 KiB | Peržiūrėta 11483 kartus(ų) ]
Autorius:  Kiesa [ 14 Lap 2010, 11:55 ]
Pranešimo tema:  Re: [E60] service engine soon indicator lamp
man atrodo viskas ten gerai pas tave.....neieskok py.... kaulu :) (kaip as) :))
Autorius:  JONAS.... [ 14 Lap 2010, 11:55 ]
tai kad va nusipirkus masina nusiperki bedu kalna. o kaip pas tave su ta lempa :lol:
manuale raso kad "service engine soon indicator lamp" ir viskas. dar radau keliuose manualuose kad :"lamp for Canadian models" , bet idomu ar pas visus ji yra ir ar dega. nes europiniuos kelete maciau ja.
Autorius:  DmK [ 14 Lap 2010, 12:12 ]
is skirtingu manualu:
Загорелась сигнальная лампа системы – показатели состава ОГ ухудшились. Как можно скорее проверьте автомобиль на СТОА BMW.
Indicator lamp for Canadian models. Under certain conditions, the indicator will blink or flash. This indicates a rather severe level of engine misfire. When this occurs, you should reduce speed and consult the nearest BMW center as soon as possible. Severe engine misfire over only a short period of time can seriously damage emissions control components, especially the catalytic converter. When the fuel filler cap is not properly tightened, the OBD system can detect the vapor leak and the indicator lamp will light up. If the filler cap is subsequently tightened, the indicator lamp should go out within a few days.
e60 diagnostic messages:
Engine fault! Drive moderately. Drive at reduced engine load. High engine loads may damage catalytic converter. Have the problem checked by the nearest BMW Service.
Autorius:  JONAS.... [ 14 Lap 2010, 12:46 ]
butent. as irgi radau sita info. bet pas mane ijungus degima kaip cia- http://www.youtube.com/watch?v=Wqen7nokjKs- neuzsidega tas varikliukas geltonas, o buna kazkas panasaus kaip cia- http://www.youtube.com/watch?v=JZHeDh_h ... re=related . tai idomu kaip kas priklauso :roll:
Autorius:  EZH [ 14 Lap 2010, 17:27 ]
pas mane uzsidega ir paskui uzgesta
Autorius:  JONAS.... [ 14 Lap 2010, 17:32 ]
na keistai cia. per skydelio patikrinima KIT TEST ji suveikia. o kuriant nea. :roll:
Autorius:  Gerdas [ 14 Lap 2010, 18:23 ]
Pas mane irgi vedant pirma uzsiziebia isvis visos skydelio lempos o paskui uzgesta, bet as 100% tikras kad pas mane ok nes isdulkinau ja iki paskutinio siulo pries pirkima.
Autorius:  NKTN [ 15 Lap 2010, 13:28 ]
Pas mane irgi ijungus degima dega visos praktiskai lemputes, ir engine lempute taip pat, po keliu sekundziu uzgesta visos ir lieka tik engine ir dirzu lempute. O uzkurus ir uzsisegus dirza dingsta visos :wink:
Autorius:  JONAS.... [ 15 Lap 2010, 16:55 ]
aiskuma :? na pas mane uzsidega tik testo tuo metu o siaip ne neblyksteli. idomu kodel gali neuzsidegti. o ar kas atkreipe demesi i komplektacijas? pas mane yra parasyta "428 warning triangle". gal cia koks uzsakymo budu variantas :roll:
Autorius:  DmK [ 15 Lap 2010, 17:15 ]
tas warning triangle panasus i avarini zenkla.
Autorius:  JONAS.... [ 15 Lap 2010, 18:03 ]
:lol: :lol: :lol: tikrai :oops:
Autorius:  nerijjus [ 18 Lap 2010, 00:15 ]
O per reset'inimo ar testavimo programas gal galima panaikinti "service engine soon" lempute?ar butina jungtis per OBD II ?
pas mane ta lempute tai uzgesta tai neuzgesta(uzvedus),o kai ji uzsidega,matyt automobilis persijungia i avarini rezima ir dingsta trauka ir apsukos kyla tik iki 2000rpm...
Autorius:  antoske bmw530d [ 25 Lap 2010, 17:21 ]
o kareiskia sis indikatoriu kai uzsidega uzvedus gal kas buvot susidure,parasykit
http://www.phpbb.com/
