Dabar yra 22 Bal 2026, 05:49
Naujos temos kūrimas Atsakyti į temą  [ 839 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 24, 25, 26, 27, 28, 29, 30 ... 56  Kitas
StandartinėParašytas: 20 Vas 2013, 14:19
E60 530d 03'
common_dream rašė:
Kiek zinau ir centrines skyles diametras E90 yra 72.5, o E60 74.1mm
Pas E60 centrine skyle 72.6 (pas E39 74.1)
StandartinėParašytas: 20 Vas 2013, 14:23
e90
jei nesunku parasykit kokie isnesimai tilptu i e90 r18
StandartinėParašytas: 20 Vas 2013, 14:25
E60 04'
e90 330 rašė:
Ne cia pataikei.
viewtopic.php?f=60&t=113913&hilit=ratai
StandartinėParašytas: 20 Vas 2013, 14:33
common_dream rašė:
E60/61 - 72.5, neklaidink zmoniu.
1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45
3 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-20
3 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-35
3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30
3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47
3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27,
3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45
3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37
5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25
5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20
5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32
5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20
6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20
7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26
7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25
7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 10-25
8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53
X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.
Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread.
Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40
Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52
Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
StandartinėParašytas: 20 Vas 2013, 16:44
2015 BMW i3 REX
2013 E93 LCI, 2.8i
2016 F25 X3, 3.5i x-Line
ex - 2004 E61 525d
Nu dar variantas galimas, jei e60 Xdrive tai berods isnesimas kaip ir e90. Nesu tikras bet rodos taip :)
StandartinėParašytas: 20 Vas 2013, 23:19
E36 318is ex
E39 523 ex
e60 530d ex
e61 525d ex
e70 3,0d
F650cs
EZH rašė:
ne visiskai toks pat,bet labai panasus.Pas e60 xdrive ciut mazesnis
StandartinėParašytas: 25 Vas 2013, 17:50
e60 530D 07' Lci
AFO001
Sveiki turiu toki klausima ar galima butu ka nors padaryti kad priekis ratlankiu nekabintu i amortikus ? Ratlankiai nuo F10 http://felgenkatalog.auto-treff.com/?felge=3310 245/40 r-19
StandartinėParašytas: 25 Vas 2013, 18:25
E60 530d 03'
AFO001 rašė:
Dek spacerius
StandartinėParašytas: 25 Vas 2013, 18:36
e60 530D 07' Lci
AFO001
o kokio storio juos det ?
StandartinėParašytas: 25 Vas 2013, 20:04
E60 530d 03'
AFO001 rašė:
Jeigu liecia amortika, tai po 15mm gali drasiai det, dar net ir daugiau.
StandartinėParašytas: 25 Vas 2013, 20:31
e60 530D 07' Lci
AFO001
o originaliu galima kur nors nupirkt ?
StandartinėParašytas: 25 Vas 2013, 21:46
E60 530d 03'
AFO001 rašė:
Nemanau, kad tokiu yra :)
StandartinėParašytas: 25 Vas 2013, 22:08
e60 530D 07' Lci
AFO001
jau radau kokiu tik nori yra http://www.ebay.com/sch/i.html?_odkw=sp ... 0&_sacat=0
StandartinėParašytas: 27 Vas 2013, 20:12
e60 530d '04 M-Tech
ex e60 530d '04
ex E46 325ci '02
sveiki kas gali pasakyt kas cia per ratai? https://www.google.lt/search?hl=lt&q=bmw+style+365&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.42965579,d.Yms&biw=1600&bih=756&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi&ei=kT0uUdP-DIXUtAbovIGADQ#um=1&hl=lt&tbm=isch&sa=1&q=bmw+f10&oq=bmw+f10&gs_l=img.3...43999.44424.19.44658.3.3.0.0.0.0.80.213.3.3.0...0.0...1c.1.4.img.3Ah5n5th0d8&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.42965579,d.Yms&fp=fa6037628db973e4&biw=1600&bih=756&imgrc=mGOlf0jTn0PrjM%3A%3B1CWLzBRBZgIsqM%3Bhttp%253A%252F%252Fpictures.topspeed.com%252FIMG%252Fjpg%252F201004%252Fbmw-f10-m5-rendering-1w.jpg%3Bhttp%253A%252F%252Fautomobilelargestate.blogspot.com%252F2011%252F11%252Fbmw-f10.html%3B1024%3B775
StandartinėParašytas: 27 Vas 2013, 20:36
E60 530d 03'
BMWe60 rašė:
Panasu i Style 332, nuo F10 arba F12
