Dabar yra 20 Kov 2026, 16:01
StandartinėParašytas: 15 Gru 2009, 19:34
BMW e60 2008m
BMW e91 2007m
BMW E38 2000m
Automobilio, apie kuri norite paklausti BMW E38
Pagaminimo metai: 2000
Variklis: 3.0
Degalai: Dyzelinas
Problema/klausimas: Sveiki, gal kas zinote kaip priristi webasto pulteli? Man tokia problema, kad kai batareika ilgai buvo nusedus, jis nebeveikia, kai pakeiciau i naujas.
StandartinėParašytas: 16 Gru 2009, 19:34
tesem tema viewtopic.php?f=18&t=54470
manuale prie webastos pultelio buvo parasyta (pats nesigilinau, neidomu):
New transmitter
If you begin to use a new transmitter (either a replacement or an additional transmitter), it must first be initialised.
Either one or two transmitters can be used. Observe the times stated below accurately, otherwise initialising will fail and have to be repeated.<
1. Remove the fuse for the auxiliary heater (in luggage compartment or
load area on right, see page 172) and insert it again after 10 seconds
2. Within 3 seconds of having inserted the fuse again, press button 3
3. Next, press button 4 within 5 seconds
4. After a further 3 seconds, the system is operational.
