Dabar yra 08 Bal 2026, 08:13
Naujos temos kūrimas Atsakyti į temą  [ 20 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2
StandartinėParašytas: 04 Vas 2008, 00:41
Pas laikrodininka po 2.5lt. nusipirkau pakeiciau ir viskas veikia kuo puikiausiai
StandartinėParašytas: 04 Vas 2008, 11:55
Copenhagen
Sveiki :)
del tos pacios bedos, raktas pasimete nuo masinos... tai ji pririsht atgal prie masinos kainavo 100 lt... pas Audriu. O kai nuseda batarke, gali naudotis raktu ir spynele elementariu budu :)
Kas keista, ne per seniausiai wel ismete panasu uzrasa "check keybattery" ar panasiai, hm, neilgai istempe batarke wadinas.
Pagaves kampa...
StandartinėParašytas: 08 Vas 2008, 21:30
Buna kad papuola lievos batarkes
StandartinėParašytas: 11 Vas 2008, 22:59
[E38] 740iA
Remote control
Changing battery
Replace the battery when the message "REMOTE KEY BATTERY" appears in the Check Control. The LED no longer lights up when a button is pressed and it is no longer possible to lock the car using the remote key. Install only a battery of the type that is specified in the battery compartment (CR 2016). Be sure the battery is installed in the correct position.
1 Use a screwdriver to lift the cover at the recess (arrow)
2 Loosen the two screws (arrows) and remove the cover.
The battery type and its installation position are stamped into the base of the battery compartment. Return used batteries to a recycling point or to your authorized BMW center.<
New transmitter
If you place a new transmitter into service (either a replacement or an additional transmitter), it must be initialized:
1 Enter the vehicle and close the driver's door
2 Briefly (max. 5 seconds) turn the ignition key to position 1 in the steering lock, then return it to position 0
3 Remove key; press and hold down button 1 (see illustration). Maintain pressure on button 1 while rapidly pressing button 2 three times in successionwithin a period of 10 seconds
StandartinėParašytas: 11 Vas 2008, 23:04
[E38] 740iA
cia rakto knopkes.
clip_image002.gif [ 4.22 KiB | Peržiūrėta 3443 kartus(ų) ]
