Dabar yra 25 Bal 2026, 22:04
StandartinėParašytas: 27 Spa 2008, 11:45
E39 523i 1997m
niekur neradau kur randasi benzino filtras.dekui uz pasisakimus.temu taipogi siuo klausimu neradau
StandartinėParašytas: 27 Spa 2008, 11:58
ex E38 735 M62 97'
ex E39 520 M47 00' Touring
ex E34 530 M60 94
justezas rašė:
filtras turetu buti po dugnu, ties vairuotojo sedima vieta. Is apacios reiktu nuimti apdaila, ir po juo rasi filtra.
The fuel filter is under the vehicle on the left side. You have to remove a plastic cover in order to actually see it. It is easy to replace. Pinch off the rubber fuel lines in front and in back of the fuel filter, then just un-clamp the hoses from the filter. Make not of which way the arrow on the filter is pointing so you can put the new fuel filter on the same way.
77994466.gif [ 106.54 KiB | Peržiūrėta 4322 kartus(ų) ]
