Dabar yra 23 Bal 2026, 03:06
Naujos temos kūrimas Atsakyti į temą  [ 710 pranešimai(ų) ]  Eiti į Ankstesnis  1 ... 19, 20, 21, 22, 23, 24, 25 ... 48  Kitas
StandartinėParašytas: 18 Geg 2015, 23:07
E87 118d 04'
C4 05'
A8 D2 00'
W220 S430 98'
E46 320d 04'
Marea 98'
Colt 96'
E38 730d 00'
E46 320Ci 02'
V40 1.9D 01'
W210 E240 98'
E38 730 95'
Norbert rašė:
Cia pirmas postas ivedus i google paieska wool ir foam skirtumus :)
"Foam pads are much more forgiving IMO. Most wool pads are VERY aggressive, and really aren't necessary on clear coat finishes. On single stage paint, wool holds more dead/oxidized paint vs. foam. On clear coats, wool tends to introduce swirls to the paint if used improperly (even sometimes if you use them properly). If you lift up on a wool pad, as you approach edges, you'll likely introduce swirls.
If your foam pad is 'grabbing' you might not be using enough product to 'prime' the pad. I use wool spot pads on occassion to level scratches, but stick with foam for everything else.
You can accomplish 95%+ with foam pads. Wool on clear coat is an exception, for very neglected or abused finishes."
Paprasciausias testas: Paemi vilnoni pada ir patrini labai greitais judesiais i delna ir ta pati padarai su foam padu ir paziurek kuris greiciau isildins ranka (ar net ant rotary poliravimo masinos uzsidejus galima :) )
Vilna naudojama tik tais atvejais kai reik daug ir greit nuimt lako ir kai isblukusi spalva stipriai yra. Bet vilna palieka daug ryksciu po saves del savo strukturos.
Ir taip, labai malonu padiskutuot su bendraminciais :)
Na kartais kuomet reikia isimti koki "galvos skausma" nuo kapoto, tai wool padai tikrai geras pasirinkimas, zinant, jog ar taip ar taip darysi antra step'a.
Su kuom dirbi? Mano kolekcijoje:
FLEX PE14-12 rotary
FLEX XC 3401 VRG
DAS6 Pro
StandartinėParašytas: 18 Geg 2015, 23:09
E87 118d 04'
C4 05'
A8 D2 00'
W220 S430 98'
E46 320d 04'
Marea 98'
Colt 96'
E38 730d 00'
E46 320Ci 02'
V40 1.9D 01'
W210 E240 98'
E38 730 95'
Tiesa ten Karchet Puzzi matau fone? Uztenka jo ar reikia galingesnio?? As vis svarstau apie gera HOT-water extractoriu. Bet LT nelabai randu kas pasiulytu su vandens pasildymu..
StandartinėParašytas: 19 Geg 2015, 23:27
E30 320i
Umburgis rašė:
FLEX PE14-12 rotary
FLEX XC 3401 VRG
DAS6 Pro
Naudoju 3M rotorini. Labai man jis patinka :) Nenoriu net Rupes pirkt. Bandziau, man nepatiko kazko... sunkus ir nera toks patogus, bet cia mano asmenine izvalga.
O Puzzio uztenka apsciai. Svarbu ne pats aparatas, o tai kokia chemija naudoji apdirbt nesvarumams. Puzzis tik istraukia purva. :)
facebook.com/cphcarcare jei idomu pazvalgyt, su kuom Daniukai vazinejasi :)
StandartinėParašytas: 20 Geg 2015, 18:14
E39 525d M57 '01
Sveiki, turiu darbe toki aparata http://www.jaunuoliai.lt/poliruoklis-makita-9227cb, su tuo paciu vilnos padu. Kaip sakot tiktu su juo poliruoti lempas? Ar geriau nusipirkti koki kempines formos? gal rekomendaciju kokiu?
StandartinėParašytas: 20 Geg 2015, 23:20
E30 320i
sarabasas rašė:
Su juo viska tiks poliruoti. Tik juosta lipnia uzdenk aplink lempa didesni plota, kad nenutarkuotum aplink ja jokiu moldingu ar ko ten.
Ir vien su tokiu padu neisgausi grazaus rezultato labai. Jei nori ledo, reik svytrint su 1500 ->> 2000 ->>> (galima ir su 2500 tada, galima ir ne) -->>> ir tada su vilnoniu ir su svelnesne dar kokia kombinacija.
Bet priklauso aisku kokio rezultato nori ir koks pas tave pazeidimas lempu. Aspektai, aspektai :)
StandartinėParašytas: 21 Geg 2015, 09:55
E87 118d 04'
C4 05'
A8 D2 00'
W220 S430 98'
E46 320d 04'
Marea 98'
Colt 96'
E38 730d 00'
E46 320Ci 02'
V40 1.9D 01'
W210 E240 98'
E38 730 95'
Norbert rašė:
Na as buvau nusipirkes panasaus galingumo i puzzi.. Tai prasikeikiau. Net kilimeliu nesugebejo normaliai istraukti, apsiputodavo pats aparatas o finale palikdavo purva pakelta pusiaukeleje bet iki galo neistraukta.. Dabar sakiau jai pirksiu tai tik su keliom turbinom ,kad trauktu kaip priklauso..
O kas del Rupes, tai as labai ji noriu isbandyti.. Kaskada nekenciau FLEX'o XC3401VRG bet ipratau tai super daiktas, dabar dazniau su juo dirbu nei su rotacine :)
Tiesa palaikinau :)!
StandartinėParašytas: 21 Geg 2015, 10:52
E39 525d M57 '01
Norbert rašė:
Del svitrinio kaip ir aisku, susisveisiu butinai. O cia ta svelnesne kombinacija tai kas? Kempine svelnesne ar pasta?
Ir siaip tas vilnonis padas labai jau didelis atrodo kaip lempu poliravimui, galvoju gal koki kita nusipirkt. Gal koki patartum? Minksta, kieta, vidutini? Kaip jie ten dar skirstos neturiu supratimo.
StandartinėParašytas: 22 Geg 2015, 02:06
E30 320i
Umburgis rašė:
Tai jei putoja, reiskias per daug produkto naudoji, o ir siaip net instrukcijoje rekomenduoja antra karta praeit su karstu svariu vandeniu grynai danga dirbama :)
Ir ačiū ^.^
sarabasas rašė:
Svelnesne kombinacija reiskia, polirolio ir pado pasirinkimas kuris bus svelnus tavo zibintu pavirsiui. Jis nuims vilnonio pado ir pastos sukeltus pazeidimus (o pastarasis nuema svitro sukelta zala), kas butina, kad pasiekt gera rezultata, ir ta kombinacija suteiks daugiau blizgesio ir skaidrumo plastikui. Reik kietesnio pado bei polirolio, kad nuimt svitrinta matini pavirsiu ta.
Galima ir svelnesni pada naudot, bet reiks procesa poliravimo pakartoti tiek kartu, kiek siurkstesnis padas ir pasta tau nuimtu per viena ejima (o gal ir du, velgi priklauso). Todel kad svelnesne kombinacija visada reikalauja daugiau laiko, nes pjovimo rezultatas yra kaip jau pats zodis "svelnesnis" sako, na ka - svelnesnis ir ilgiau trunkantis :D
O ziurek ciupinedamas. Pasta irgi reik pagal pada rinkt dazniausiai, nes paimsi minksta pasta ant kieto pado ir nenuimsi ibrezimu, o tik suteiksi blizgesi matiniam pavirsiui. Zodziu. emi kieta kombo -->>> tada vidutini seta --->>> svelnu seta. Wuala.
StandartinėParašytas: 22 Geg 2015, 07:19
E39 525d M57 '01
Dekui uz info, viskas mazdaug aisku.
StandartinėParašytas: 01 Bir 2015, 20:49
E39 528i
Sveiki, poliravime visai zalias as, tik video prisiziurejes. Norisi paciam siek tiek pasigrazinti kebula su turimais irankiais ir medziagom, na ir siandien pabandziau. Poliravimo pasta pirkta pries 3 metus, zinau tikrai kad 3M, pyle is juodos bankes su baltu kamsteliu (tai kokio cia ji rupumo?), turiu balta minksta stora padeli ir oranzini kietesni bei vilnoni. Ir dar kas, kad dirbu su drele :oops: Taigi bandziau daryti kapota siandiena ir trink netrynes, matosi ibrezimai visvien, kad ir su kuriuo padu sukciau. Lakas itin kietas, niekad negaves jokios meiles, zodziu labai sunku buvo su drele daryti.
Taigi paaiskinkit man, koks yra teisingas kiekis produkto imant nedideli plota, 3x3 pado skersmens? Ar pagerestu kokybe jeigu dirbciau su tam skirta masinele? (be throw'o? ). Po pirmo step'o, koki produkta rinktis (ir kur gauti Kaune) toliau, kad uzpildyt likusius ibrezimus? Ar antram zingsniui teisingas pasirinkimas yra microfiber cutting pad?
Labai ačiū uz atsakymus :)
StandartinėParašytas: 03 Bir 2015, 21:11
E87 118d 04'
C4 05'
A8 D2 00'
W220 S430 98'
E46 320d 04'
Marea 98'
Colt 96'
E38 730d 00'
E46 320Ci 02'
V40 1.9D 01'
W210 E240 98'
E38 730 95'
prodrive rašė:
Visu pirma pradekim nuo to, kad reikalinga tau normali poliravimo masinele.. Jaigu domina galiu uz 270EUR padaryt Rupes LH18ENS
StandartinėParašytas: 14 Bir 2015, 20:48
E30 320i
MRDetailing rašė:
Sakoma yra: geram sokejui, kojos netrugdo. Reik pradet nuo pagrindu pranokimo, tada jau eit prie irangos :) Jei jis nezinos, kaip isdirbt poliroli ir kokiu kiekiu naudot ji, jam ir tas Rupes nepades.
prodrive paziurek kaip jau sakes esu Junkman2000 yra kogero geriausias budas ismokt pagrindu poliruojant.
StandartinėParašytas: 18 Bir 2015, 15:40
E87 118d 04'
C4 05'
A8 D2 00'
W220 S430 98'
E46 320d 04'
Marea 98'
Colt 96'
E38 730d 00'
E46 320Ci 02'
V40 1.9D 01'
W210 E240 98'
E38 730 95'
Norbert rašė:
Jaigu trins su senukine masinele, tai gyvenime nieko neismoks, net ir prisiziurejas video. Pats ta praejau.. Kol nebuvo tinkamos irangos tol darbas buvo 0 vertes.
StandartinėParašytas: 27 Bir 2015, 21:40
Prie temos - gal kas gali paaiškinti ką daryti, kad po plovimo neliktų nudžiuvusių vandens taškų? Iš pradžių galvojau, kad nenuplaunu purvo normaliai, vėliau, kad gal vanduo kaltas, ar vaškas (savitarnos plovyklų) kaltas. Ar būtina sausint mikropluošto šluostėmis?
StandartinėParašytas: 28 Bir 2015, 09:27
E46 320D '02 universalas AT
Gentle rašė:
Butina sausinti.
