| [E36] Skaitmeninis spidometras/tachometras https://forumai.bmw-klubas.lt/viewtopic.php?f=29&t=36692 |
Puslapis 1 iš 2 |
| Autorius: | Stigas [ 16 Gru 2007, 14:00 ] |
| Pranešimo tema: | [E36] Skaitmeninis spidometras/tachometras |
BMW dar kart maloniai nustebino Ismeginau, veikia puikiai Tai va. Funkciju ijungimo procedura butu tokia: 1. Paspausti ir laikyti kilometrazo nunulinimo mygtuka (uzvedimo raktelis spyneleje , padetis 0 ) 2. Pasukti rakteli i pirmaja padeti ir atleisti kilometrazo nunulinimo mygtuka. 3. Ekranelyje atsiras uzrasas "test 01". Spaudineti kilometrazo nunulinimo mygtuka ( keisis "test" reiksmes 02,03... 15 ). Kuomet test reiksme bus "14" paspausti mygtuka dar karta ir laikyti kol pasirodys uzrasas "off". Funkcijos "atrakintos" ! As naudojuosi tik keliomis (07 , 08 ) 07 - tachometras 08 - spidometras Issamiau apie viska galit paskaitinet cia: Cituoti: If you have a post '97 E36 4 door/coupe/convertible/M3, '95-present 318ti,
'96 -present Z3, you can do tests including a digital tachometer and yes it can be used while driving although I DON'T RECOMMEND IT! NOTE: *Test functions 1-4 are unlocked tests and can be called up at any time for display. *Test functions 5-14 are locked and require unclocking the test mode before they can be displayed. *Test functions 2-14 can be selected at any time when the cluster is unlocked, even when vehicle is moving. *Test function 15 is the lock/unlock function. Step 1: Press and hold the mileage reset button. Step 2: Put key into ignition switch and turn to KLR (Ignition switch position #1) Your LCD display will show something like this "tESt 01" Step 3: You will need to unlock the test function first so when the LCD Display shows "tESt 01", press the reset button till you get to "tESt 15". Once you're on test 15 press, and hold the reset buton for a few seconds until it displays "off". Now you can cycle through the test features. Here they are as they follow: Test 1: Instrument self test Test 2: Engine Data - This display is an "engine factor" value that is stored in the coding plug. The instrument cluster processor uses this factor in addition to the "TD" signal from the DME control module to process and display tachometer RPM based on the engine installed. For EXAMPLE: *ENGINE FACTOR 2 = 4 CYLINDER *ENGINE FACTOR 3 = 6 CYLINDER *ENGINE FACTOR 4 = 8 CYLINDER Test 3: SI elapsed distance - the total mileage in kilometer since the last reset. Which service is due at the next inspection (OIL SERVICE or INSPECTION) Test 4: SI elapsed days - no value for US vehicles. Relates to Euro annual inspections. Test 5: SI evaluation factor - for engine speed and temp. thresholds being passed. Display: n = 0 or 1. engine speed (over-rev) t = 0 or 1. engine temp. Test 6: Fuel Level and coolent temp. - Display of hexadecimal codes in relation to gauge position. Fuel gauge Hex value A (empty)----------> 0d End of reserve------> 37 B-------------------> 54 C-------------------> 90 D-------------------> c4 E (full)--------------> f0 Engine temp. Hex Value A-------------------> čia B-------------------> 6d C-------------------> 5c D (center)----------> 4f-23 E-------------------> 1e F-------------------> 18 Test 7: Engine speed - display of current engine speed Test 8: Road speed - display of current road speed in km/h Test 9 Distance reading - this allows the total stored mileage to be updated if one of the storage components has to be replaced. This test step will be used if the manipulation dot is illuminated in the cluster display. Ths display will show the component with the lower mileage. For example: Display of 012654 l indicates that the mileage in the internal EEPROM is lower than the milage stored in the coding plug. Display of 000325 E indicates that the mileage in external coding plug is lower then the total mileage stored in the internal EEPROM. Pressing the reset button for 4 seconds will over write the lower mileage with the higher mileage and cancel the manipulation dot. The SI data will also be transferred at the same time. Test 10: Status bits (input signals) - the status of digital inputs to the cluster are displayed as 0 or 1. Display: 0 = input low, 1 = input high. _ _ _ _ _ _ <--- Mileage display...6 digits left to right 1st - belt contact, seat belt fastened = 0 2nd - ignition lock contact, key inserted = 0 3rd - door contact, door open = 0 4th - clock button pressed = 0 5th - SI reset = 0, for reset = 0 6th - EGS transmission failure = 0 Test 11: Status Bits (output signals) - the status of digital outputs is displayed. Display: 0 = output inactive, 1 = output active _ _ _ _ _ _ <--- Mileage display...6 digits left to right 1st - Gond output 2nd - Brake warning lamp 3rd - Low fuel warning lamp 4th - EGA lamp 5th - seat belt lamp 6th - manipulation dot Test 12: not used Test 13: Country code of cluster - the display indicates the country version of the cluster. This cannot be changed in the workshop. Display: USA 02 Test 14: Software Reset - The reset must be carried out if any faults are present that are not plausible before any components are replaced. After the reset, the system will exit the TEST mode and the lock will be reactived. Test 15: lock/unlock NOTE: KLR means ignition switch position #1 (accessory) KL-15 is ignition switch position #2 (on), and KL-50 is ignition position #3 (start) "TD" is engine speed signal. Try not to use the engine speed and road speed while driving. The display is too low and you have to read instead of glancing which takes too much time taking away your eyes off the road. Hope this test brings some fun and interest to you all. |
| Autorius: | Povilass [ 22 Gru 2008, 12:43 ] |
| Pranešimo tema: | Re: [E36] Skaitmeninis spidometras/tachometras |
tai ant 15 palaikyk kad is on pasidarytuu off ir viskas veiks. |
| Autorius: | bemsius11 [ 11 Sau 2009, 17:54 ] |
| Pranešimo tema: | Re: [E36] skaitmeninis spidometras/tachometras |
Tikrai eina jei OBC su ilgaja eilute (rodo ir apsukas, ir greiti, variklio temp, kuro likuti bake su desimtosiom litro dalim, vidutines kuro suanaudas per val., momentini kurso sunaudojima /100km, ir t.t. ir t.t.) Kaip dėl OBC su mašinytės paveiksliuku nežinau.[/quote] Taip, as kalbejau butent apie OBC su masinytes logo. |
| Autorius: | karceris [ 22 Sau 2009, 15:36 ] |
padarau as ta 15 funkcija OFF uzvedu bmw, spaudineju nuresetinimo mygtuka ta, ir nieko ten nerodo, tik kad 0 km nuvaziavau. kame beda gali buti? atrodo viska gerai darau. |
| Autorius: | Exeed [ 29 Sau 2009, 23:41 ] |
14-oje funkcijoje vietoj OFF rodo ------ (brūkšniukus). Tai kaip suprasti? Skydelis iš E36 M3 (kurių metų nežinau). REDAGUOTA: viskas veikia perskaičius ir supratus instrukciją iki galo Tikrai smagus dalykėlis tie visi besikeičiantys skaičiukai |
| Autorius: | Povilass [ 30 Sau 2009, 16:08 ] |
15 funkcija reikia off padaryt. |
| Autorius: | Povilass [ 09 Vas 2009, 17:30 ] |
stai kaip veikia viena is funkciju.. http://www.youtube.com/watch?v=UMZUYGBB ... re=related |
| Autorius: | Snepseris [ 24 Vas 2009, 15:27 ] |
Gal yra kokiu panasiu bajeriu ant E36, 92m.? Bandziau sita, tai nieko nesigavo, kaip vienas kolega minejo, parode kazkokius skaicius ir visas rodykles nulenke iki galo ir atlenke atgal |
| Autorius: | Ginttas [ 21 Vas 2010, 13:39 ] |
gal zinot kas nors kai darai testa ten kai pradeda rodyti pvz. 1. 0000000km 2. 172km ka koks skaiciukas reiskia ten ju yra apie 6 |
| Autorius: | JUKE [ 23 Vas 2010, 21:03 ] |
Ginttas rašė: gal zinot kas nors kai darai testa ten kai pradeda rodyti pvz. 1. 0000000km 2. 172km ka koks skaiciukas reiskia ten ju yra apie 6 pirma puslapi paskaityk |
| Autorius: | arvydas bmw [ 28 Kov 2010, 21:48 ] |
o su tom fumkcijom ar galima mylias pakeisti i kilometrus ar reikia varyt i diagnostika... |
| Autorius: | Exeed [ 30 Kov 2010, 20:32 ] |
arvydas bmw rašė: o su tom fumkcijom ar galima mylias pakeisti i kilometrus ar reikia varyt i diagnostika... Skydelio rodmenys iš mylių į kilometrus nėra taip paprastai keičiami. Nors ir atrodo paprasta konversija, bet gamintojas nėra numatęs keisti mylias į kilometrus ar kilometrus į mylias netgi programavimo būdu. Jei E36 skydelis "gimė" su myliomis, tai taip ir bus visąlaik, nors apačioje ir matomas km indikatorius. Teko domėtis tuo ir rimti specialistai po viso dienos elektroninių žaidimų su juo rimtai pasakė, jog E36 skydelis neperprogramuojamas ir kitaip nemodifikuojamas (skaitmeninė pusė). Mano atveju tai buvo 1996 metų E36 M3 skydelis myliomis (U.K.). |
| Autorius: | Andrius S. [ 12 Lap 2010, 17:26 ] |
Stigas rašė: BMW dar kart maloniai nustebino Ismeginau, veikia puikiai Tai va. Funkciju ijungimo procedura butu tokia: 1. Paspausti ir laikyti kilometrazo nunulinimo mygtuka (uzvedimo raktelis spyneleje , padetis 0 ) 2. Pasukti rakteli i pirmaja padeti ir atleisti kilometrazo nunulinimo mygtuka. 3. Ekranelyje atsiras uzrasas "test 01". Spaudineti kilometrazo nunulinimo mygtuka ( keisis "test" reiksmes 02,03... 15 ). Kuomet test reiksme bus "14" paspausti mygtuka dar karta ir laikyti kol pasirodys uzrasas "off". Funkcijos "atrakintos" ! As naudojuosi tik keliomis (07 , 08 ) 07 - tachometras 08 - spidometras Issamiau apie viska galit paskaitinet cia: Bet cia ne pas visus kaip supratau, nes ant savojo pabandziau, tai tik tas skydelio testas isijungia ir tiek |
| Autorius: | GiedriusGP [ 22 Lap 2010, 21:03 ] |
Poto išjungus variklį ir vėl jį užvedus, viskas vėl atsistato ir skidelis rodo įprastus rodmenys? |
| Autorius: | neasin [ 29 Lap 2010, 01:23 ] |
Ant E46 320D šitas tikrai veikia - išmėginau:) nors ne viską supratau ka kas reiškia Instructions to access the hidden OBC functions: 1. Hold Trip Reset while turning ignition key to on position 2. OBC should show "Test" 3. Use Trip Reset to select function 19.0 that unlocks all the features 4. Wait for display to show "Off" 5. Depress Trip Reset for 1/4 second and release it 6. With no delay press Trip Reset several times to select one of the following function s BMW E46 On-Board Computer (OBC) Hidden Codes nr example description 1 Car Engine and cluster data 1.0 46nnn Chassis nr/VIN serial number (last 5 digits) 1.1 4nnn K-number 1.2 690236 Cluster Part # 1.3 045210 Coding (04)/diagnosis (52)/bus index (10) 1.4 1200 Week (12)/year of manufacture (2000) 1.5 09_160 Hardware (09) and software # (16.0) of cluster 1.6 Not used 1.7 04__44 CAN-version (04) KI-revision index (44) 2 (test) Cluster System Test - Activates the gauge drivers, indicators and LEDs to confirm function 3 SI Data 3.0 1098 Used fuel in liters since last SI (Service Inspection) 3.1 0231 Periodic inspection days; elapsed days (since last SI) 4 Momentary Consumption 4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km 4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour 5 Distance Gone Consumption 5.0 082 Average mileage; 082=8.2 liters/100km 5.1 0536 Calc. km to refuel (momentary distance to go) 6 Fuel Level sensor inputs in liters 6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters 6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters 6.2 0442+ Indicated value (44.2) and tank phase 7 Temperature and Speed 7.0 021+ Coolant/Engine temperature (2.1C) 7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135 7.2 + Engine speed / Current RPMs 1/min 7.3 + Vehicle speed / Current Speed in km/hour 8 Input value in HEX form 8.0 1d0+ System voltage ADC-Value Hex code 8.1 26C33C+ ADC Values HG left/HG right 8.2 0000 ADC Value brake degradation sensor (000=o.k.) 8.3 18C ADC Value outside temperature 9 Battery 9.0 140 Battery Voltage - 140 = UB 14.0v 9.1 242013+? 9.2 074_78+? 9.3 0011+? 10 Not used 11 Not used 12 Not used 13 GonG Gong Test 14 Not used 15 Status cluster I/O-ports (bit codes) 0=low; 1=high 1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0 Status Digital Outputs (bits) 0=inactive, 1=active 1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot 16 Not used 17 Not used 18 Not used 19 Lock Status; unlocks functions in range 3-18 19.0 L-On/L-Off Unlock: press button when "L-Off" 20 Not used 21 Software Reset; reset OBC settings 00 End of test |
