Dabar yra 22 Bal 2026, 22:04
Naujos temos kūrimas Atsakyti į temą  [ 36 pranešimai(ų) ]  Eiti į Ankstesnis  1, 2, 3  Kitas
StandartinėParašytas: 11 Kov 2010, 04:29
E36 325i m50 vanos coupe 93m.
E46 330i 01m.
kurioj vietoj airijoj randies?
StandartinėParašytas: 11 Kov 2010, 13:58
E39 520 2001
Galima sakyti Dubline o tiksliau sworde...
StandartinėParašytas: 12 Kov 2010, 04:36
E46 330i 01m.
akadeepart rašė:
galiu duot vieno zmogaus kontaktus gal jis ka pagelbes,jei sestadieni nieko nerasi.
StandartinėParašytas: 12 Kov 2010, 13:27
E39 520 2001
Jaigu gali parasyt PM arba parasyk cia... ačiū...
StandartinėParašytas: 16 Kov 2010, 01:04
E39 520 2001
Sveki taigi gavau klaidu kodus,stai tokie:
CA/B1 - Oxygen sensor control, bank 1, control limit, mixture limit rich
CB/B1 - Oxygen sensor control, bank 2, control limit, mixture limit rich
E3/B1 - Oxygen sensor controller, bank 1, deviation too great, deviation rich
E4/B1 - Oxygen sensor controller, bank 2, deviation too great, deviation rich
EE/B2 - Misfire, cylinder 1, misfiring during warm up, worsening emissions (Misfire CARB_B1)
F2/B3 - Misfire, cylinder 5, misfiring with cylinder cutout (Misfire CARB_A), misfiring during warm up, worsening emissions (Misfire CARB_B1)
F0/B6 - Misfire, cylinder 3, misfiring during warm up, worsening emissions (Misfire CARB_B1), misfiring at operating temperature, worsening emissions (Misfire CARB_B4)
F3/B3 - Misfire, cylinder 6, misfiring with cylinder cutout (Misfire CARB_A), misfiring during warm up, worsening emissions (Misfire CARB_B1)
EF/B2 - Misfire, cylinder 2, misfiring during warm up, worsening emissions (Misfire CARB_B1)
08/B2 - Air mass flow sensor signal, short circuit to negative or open circuit
5A/12 - Exhaust temperature before catalyst, bank 1, signal line, short circuit to negative
5C/12 - Exhaust temperature after catalyst, bank 1, signal line, short circuit to negative
5B/12 - Exhaust temperature before catalyst, bank 2, signal line, short circuit to negative
5D/12 - Exhaust temperature after catalyst, bank 2, signal line, short circuit to negative
85/08 - Signal, CAN ASC 3, timeout elapsed
Ir stai tokie rusu kalaba atsakymai :
Спасибо всем. Как это не бонально но после замены вентиляции картера - шланги все забиты гадостью были, двигатель заработал как новенький. За 40 минут работы ошибок не выбил.
Вот человек на другом форуме раставил все на места по спору смесь бедная или богатая. Может кому пригодится в будущем. Еще раз всем спасибо.
Ошибка не по богатой смеси - а по пределу обогащения, на которое способен ДМЕ. Т.е. смесь в данном случае была бедная. Т.Е. ДМЕ её пытался обогатить, но так и не смог, достигнув своего предела.
Gal kas gali padeti ir paaiskinti smulkiau kaip ir ka cia tas zmogus dare.. ačiū
StandartinėParašytas: 16 Kov 2010, 01:42
akadeepart rašė:
Cituoti:
pakeite karterio alsuokli. tik ne klausk kaip :twisted: yra forume apie tai + tis
StandartinėParašytas: 16 Kov 2010, 02:04
E46 330i 01m.
tai dabar jau tokius kodus meta.
http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
detale nr.1
cia kaip tai atlikti.beto but neprosali patikrint vakumines slangas
http://www.bimmerfest.com/forums/showth ... p?t=354754
StandartinėParašytas: 19 Kov 2010, 21:55
E39 530d
o esant tokiems nesklandumams kas darosi normaliai vaziuojant ? jauciasi kasnors negero? o tia svogeriui 3Ld 142kw sake ant laisvu kartais susipurto variklis, apsukos pakrenta ,paskui atsgauna ,bet vaziuojant normaliai lyg viskas ,tai galvoju gal kazkas panasaus bus ? kita sav prie kompo jungsim tai bus aiskau, bet siaip idomu pasidare del simptomu :)
StandartinėParašytas: 12 Vas 2014, 12:56
Klaipėda - Bergen
Ex... E39 528I
Ex... E39 525I
Ex....E39 530IA
E39 530D 225Ag 490NM
Skype
Nikas
E39 1999m. M52TUB20 Problema. Nedirba normaliai 6 cilindras, kartais kvailioja ir 2. Niekaip nevyksta surast problemos, tai kreipiuosi i jus gal kazkas susiduret ar turit minciu uz ko kabintis? Idedu video su gyvais parametrais ir kaip dirba variklis.
StandartinėParašytas: 13 Vas 2014, 12:00
E36 318is sedan
E39 530d "Shadow Line"
jeigu babinos vietomis sukeisti, kas vyksta? pvz 6 su 5?
StandartinėParašytas: 13 Vas 2014, 15:44
Klaipėda - Bergen
Ex... E39 528I
Ex... E39 525I
Ex....E39 530IA
Skype
Nikas
.:Pashka:. rašė:
zvakes naujos, buvau sukeites babinas ir naujas, kolektoriaus tarpine nauja, vakumas tvarkingas, vistiek svaigsta 6 cilindras. Idomu pats ecu gali kvailioti? jau nebezinau ka ir bedaryt.
StandartinėParašytas: 13 Vas 2014, 17:35
E39 523i 1997m
Pas mane panasiai labai buvo(uzkurus kratesi kaip traktorius,variklis pulsavo saltas kaip garvezys),susilus gerokai geriau....bet kartais apsukos vistiek pasokinedavo ant laisvu sustojus prie sviesaforo.Trauka normali,skirtumo kazkokio nepajutau(nes masina jau 6 metus turiu).O visame tame kratimesi radau problema,siektiek pataisiau savo turimomis mendziagomis po ranka.Bet labai neilgam.Nes tepalas vel prarasisunke ir sandarumo nebera.
http://s4.postimg.org/m7o557rkd/20140114_151134.jpg
http://s4.postimg.org/tz4v3rvpp/20140114_151209.jpg
pasikeiskite sitas dvi dalis :
nr: 1 ir 2.
http://s30.postimg.org/61oire13l/alsuoklio_sistema.png
Turetu problema issispresti.
StandartinėParašytas: 13 Vas 2014, 22:33
Klaipėda - Bergen
Ex... E39 528I
Ex... E39 525I
Ex....E39 530IA
Skype
Nikas
justezas rašė:
nr: 1 ir 2.
tepalo separatorius tvarkingas, nera jokio plysio ar blogos zarnos, membrana nauja.
Klausimas - ar gali taip but del galvos tarpines?
StandartinėParašytas: 14 Vas 2014, 11:36
E36 318is sedan
Andrelisklp rašė:
aisku gali ir kompas buti, patikrink kompresija
StandartinėParašytas: 19 Vas 2014, 23:10
Klaipėda - Bergen
Ex... E39 528I
Ex... E39 525I
Ex....E39 530IA
Skype
Nikas
.:Pashka:. rašė:
zodziu laukia kapitalinis, kogero tarpine, 6 cilindre kompresija 6 barai, kituose po 12 - 13bar.
