[E36] Priekines lempos - Bosch ir ZKW?
https://forumai.bmw-klubas.lt/viewtopic.php?f=100&t=38672
Puslapis 14
Autorius:  eMJei [ 13 Bal 2006, 17:35 ]
Pranešimo tema:  Kurios E36 faros prieki geriau ZKW ar BOSCH?
Reik apsisprest ka pasilikti ka parduoti. Pagal realoem BOSCH brangesnes 70
USD. Tai manau ir apie kokybe pasako nemazai? Ka jus manot? Argumentai ?
Dekui. Faros be leshiu, su "burbuliukais" , tipo naujesnes, i 1995 metu mano
BMW.
eMJei
E36'95
Autorius:  Fla [ 18 Geg 2007, 16:57 ]
Pranešimo tema:
Kaip suprantu tu BOSCH ir ZKW kaip ir ne viena modifikacija buvo.
Zr. cia:
"Ellipsoid" headlights were manufactured by both ZKW and Bosch for European E36 BMWs sold from '91-'94.
The ZKW's are BMW Parts 63121393271 (Drivers) and 63121393272 (Passengers) and ZKW Parts 519.01.000.01 (D) and 519.02.000.01 (P).
The Bosch's are BMW Parts 63121387041 (D) and 63121387042 (P) and Bosch Parts 0 301 087 025 (D) and 0 301 087 026 (P).
These parts each come with two 55W H1 bulbs.
Interestingly, the "Ellipsoid" lenses in the headlight's projector aren't actually ellipsoids - they are ellipsoidal domes. The front of the headlight lens is curved, but the back of the lens is flat. A true ellipsoid would be curved all the way around like a sphere.
Later revisions of both the ZKW and Bosch European E36 headlights do not use "Ellipsoid" lenses.
I've never seen European non-Ellipsoid headlights myself, so I can't compare them to the Ellipsoids, but everyone seems to consider the Ellipsoids to be better.
Given the availability of Ellipsoid headlights, I doubt there is much reason to buy non-Ellipsoid headlights.
For E36 BMWs from 5/94 to 9/94, both ZKW and Bosch manufactured European non-Ellipsoid headlights with H1 bulbs.
The ZKW's are BMW Parts 63128363079 (D) and 63128363080 (P) - I'm not positive on the ZKW Part Numbers, but they may be 519.01.000.02 (D) and 519.02.000.02 (P).
The Bosch's are BMW Parts 63128363081 (D) and 63128363082 (P) and Bosch Parts 0 301 087 035 (D) and 0 301 087 036 (P).
For E36 BMWs from 95-99, both ZKW and Bosch manufactured European non-Ellipsoid headlights with H7 bulbs.
The ZKW's are BMW Parts 63128363495 (D) and 63128363496 (P) - I'm not positive on the ZKW Part Numbers, but they may be 519.11.000.01 (D) and 519.12.000.01 (P).
The Bosch's are BMW Parts 63128363493 (D) and 63128363494 (P) and Bosch Parts 0 301 095 003 (D) and 0 301 095 004 (P).
Itariu "geltonuoja" tik tos naujesnes, bet kiek tame tiesos - nezinau.
Kiek ziurejau - BOSCH paprastai laikoma equal or superior to ZKW ;)
Tikiuos bus naudinga (jei ne tau, tai bent kazkam kitam, kas veliau ras sita info;)
Autorius:  all in music [ 18 Geg 2007, 17:58 ]
Pranešimo tema:
kiek anksciau teko paciam dometis tai:
Bosch - lesinis / nelesinis
ZKW - lesinis / nelesinis
Hella - lesinis / nelesinis
tarp ju nera skirtumo. Bosch ir ZKW ejo is gamyklos, bijau sumeluoti, bet man rodos, kad ir su Hella ejo.
dejausi Hella lesinias, su burbuliukais buvo (ant naujesniu metu auto su burbuliukais). cia lyg del stiprumo stikliuko, ar kazkas pan.
palik kokios yra, nes skirtumo nera, o bereikalingas darbas bus :wink:
Autorius:  Edga88 [ 19 Sau 2008, 18:36 ]
Pranešimo tema:  [E36] Priekines lempos - Bosch ir ZKW?
Sveiki
pas mane situacija tokia kad nusipirkau is zmogaus dvi originalias lempas priekines. dabar bededamas xenonus pamaciau kad jos skirtingos. viena Bosch o kita ZKW. principe kiek ziurejau tai jos ten labai nesiskiria tik vienas priekinis stikliukas su pertvarom o kitoj ne. ir lesiai skiriasi.
tai va klausimas toks kaip svies ar vienodai kai sudesiu ? ar jau iskarto ieskotis dar vienos ?
lempos.JPG [ 35.1 KiB | Peržiūrėta 13982 kartus(ų) ]
Autorius:  Andrius S. [ 19 Sau 2008, 19:12 ]
Pranešimo tema:  Re: [E36] Priekines lempos - Bosch ir ZKW ?
manau viena kazkuria parduok ir nusipirk vienodas :wink:
Autorius:  Edga88 [ 19 Sau 2008, 19:21 ]
na o jei pirktis nauja tai kuria ? :? kuris lesis geresnis ?
Autorius:  Grill [ 19 Sau 2008, 19:35 ]
Bosh graziau ziurysi ;)
Pas mano pazystama yra ZKW, o pas mane BOSH, nezinau kodel, bet vidiniai stikliukai graziau atrodo ir nenesa i gelsvuma.
Autorius:  arnoldasbmw [ 19 Sau 2008, 21:29 ]
manojoj E36 , dvi skirtingos lempos, viena bosh, kita net nzn , ir vienodai sviecia .... manau neskubek ju keist, nebent rasi kam vienos lempos prireiks, o jei pinigus mest lauk tai #-o . o del lempu pasirinkimo, pasilikciau BOSH :wink:
Autorius:  Henris [ 30 Bal 2008, 10:02 ]
tas ZKW yra fufeliai, buvau nusipirkes masina irgi su vienu BOCH kitu ZKW zibintu , kaip nekeista tech. apziura praejau su skirtingais, bet prie progos pakeiciau i BOSHa. Originalio eina tik BOSH arba HELLA , nors labai daznai pasitaiko ir Vokietijoj masinos su ZKW zibintais
Autorius:  all in music [ 30 Bal 2008, 10:08 ]
Henris rašė:
originalios yra BOSCH, ZKW, Hella. neklaidink zmoniu.
Autorius:  Tadasas [ 30 Bal 2008, 10:12 ]
Henris rašė:
tas ZKW yra fufeliai... Originalio eina tik BOSH arba HELLA...
Geras pasakorius :D
Paziurim cia: http://bmwfans.info/original/E36/Cou/32 ... l-63_0267/
O siaip man grazesnes ZKW, nes tamsesnes :wink:
Autorius:  Kywon [ 30 Bal 2008, 10:46 ]
aš irgi už ZKW. Liašis sidesnis, aišktu tai dideles reikšmės neturi, nes esmė reflektoriuje, bet kažkaip gražiau žiūrisi. :)
Ir šiaip kiek USA forumuose teko skaitinėti, tai tie kurie nori susistatyt xenonus, siunčiasi europines originalias ZKW lempas. Ir nemažus pinigus už tai moka. :D
Autorius:  edzhy [ 01 Geg 2008, 13:41 ]
Tavo reikalas, aš prijaučiu Bosch'ams, tai juos ir susidėjau. Toks retorinis klausimas, yra originalių baltų posūkių E36? Nusipirkau Depo papigiai, tikiuosi laikys :roll:
Autorius:  aukor [ 06 Geg 2008, 23:44 ]
Jei kas nores keistis Bosch i ZKW - msg me ;) Irgi akys skirtingos :) Beje kas liecia posukius, tai siulau dar papildomai is vidaus juos pritvirtint, nes as sau pirkau ta taivanio gamybos ir per savaite jis man sugebejo iskristi :) Reiks velnias dar viena pirkt ir jau kokia plona vielute ar spyruokle "prisabachint" prie kebulo is variklio puses.
Autorius:  all in music [ 07 Geg 2008, 09:24 ]
pakeiciau 3 komplektus posukiu. reikejo keist tik del to, kad sulauzdavau fiksatoriu kur prie faros tvirtina posuki. o siaip viskas ten gerai su jais...
Puslapis 14 Visos datos yra UTC + 2 valandos [ DST ]
http://www.phpbb.com/
