Dabar yra 12 Kov 2026, 21:27
Naujos temos kūrimas Atsakyti į temą  [ 57 pranešimai(ų) ]  Eiti į 1, 2, 3, 4  Kitas
StandartinėParašytas: 13 Bal 2006, 17:35
Reik apsisprest ka pasilikti ka parduoti. Pagal realoem BOSCH brangesnes 70
USD. Tai manau ir apie kokybe pasako nemazai? Ka jus manot? Argumentai ?
Dekui. Faros be leshiu, su "burbuliukais" , tipo naujesnes, i 1995 metu mano
BMW.
eMJei
E36'95
StandartinėParašytas: 18 Geg 2007, 16:57
E39 540 00' |
E46 318 03' |
ex E36 316 93' |
ex E36 325 coupe 92'
Kaip suprantu tu BOSCH ir ZKW kaip ir ne viena modifikacija buvo.
Zr. cia:
"Ellipsoid" headlights were manufactured by both ZKW and Bosch for European E36 BMWs sold from '91-'94.
The ZKW's are BMW Parts 63121393271 (Drivers) and 63121393272 (Passengers) and ZKW Parts 519.01.000.01 (D) and 519.02.000.01 (P).
The Bosch's are BMW Parts 63121387041 (D) and 63121387042 (P) and Bosch Parts 0 301 087 025 (D) and 0 301 087 026 (P).
These parts each come with two 55W H1 bulbs.
Interestingly, the "Ellipsoid" lenses in the headlight's projector aren't actually ellipsoids - they are ellipsoidal domes. The front of the headlight lens is curved, but the back of the lens is flat. A true ellipsoid would be curved all the way around like a sphere.
Later revisions of both the ZKW and Bosch European E36 headlights do not use "Ellipsoid" lenses.
I've never seen European non-Ellipsoid headlights myself, so I can't compare them to the Ellipsoids, but everyone seems to consider the Ellipsoids to be better.
Given the availability of Ellipsoid headlights, I doubt there is much reason to buy non-Ellipsoid headlights.
For E36 BMWs from 5/94 to 9/94, both ZKW and Bosch manufactured European non-Ellipsoid headlights with H1 bulbs.
The ZKW's are BMW Parts 63128363079 (D) and 63128363080 (P) - I'm not positive on the ZKW Part Numbers, but they may be 519.01.000.02 (D) and 519.02.000.02 (P).
The Bosch's are BMW Parts 63128363081 (D) and 63128363082 (P) and Bosch Parts 0 301 087 035 (D) and 0 301 087 036 (P).
For E36 BMWs from 95-99, both ZKW and Bosch manufactured European non-Ellipsoid headlights with H7 bulbs.
The ZKW's are BMW Parts 63128363495 (D) and 63128363496 (P) - I'm not positive on the ZKW Part Numbers, but they may be 519.11.000.01 (D) and 519.12.000.01 (P).
The Bosch's are BMW Parts 63128363493 (D) and 63128363494 (P) and Bosch Parts 0 301 095 003 (D) and 0 301 095 004 (P).
Itariu "geltonuoja" tik tos naujesnes, bet kiek tame tiesos - nezinau.
Kiek ziurejau - BOSCH paprastai laikoma equal or superior to ZKW ;)
Tikiuos bus naudinga (jei ne tau, tai bent kazkam kitam, kas veliau ras sita info;)
Fla
StandartinėParašytas: 18 Geg 2007, 17:58
kiek anksciau teko paciam dometis tai:
Bosch - lesinis / nelesinis
ZKW - lesinis / nelesinis
Hella - lesinis / nelesinis
tarp ju nera skirtumo. Bosch ir ZKW ejo is gamyklos, bijau sumeluoti, bet man rodos, kad ir su Hella ejo.
dejausi Hella lesinias, su burbuliukais buvo (ant naujesniu metu auto su burbuliukais). cia lyg del stiprumo stikliuko, ar kazkas pan.
palik kokios yra, nes skirtumo nera, o bereikalingas darbas bus :wink:
StandartinėParašytas: 19 Sau 2008, 18:36
E39 525i
Ex
E36 320i
E34 525d 535i
Sveiki
pas mane situacija tokia kad nusipirkau is zmogaus dvi originalias lempas priekines. dabar bededamas xenonus pamaciau kad jos skirtingos. viena Bosch o kita ZKW. principe kiek ziurejau tai jos ten labai nesiskiria tik vienas priekinis stikliukas su pertvarom o kitoj ne. ir lesiai skiriasi.
tai va klausimas toks kaip svies ar vienodai kai sudesiu ? ar jau iskarto ieskotis dar vienos ?
lempos.JPG [ 35.1 KiB | Peržiūrėta 13973 kartus(ų) ]
StandartinėParašytas: 19 Sau 2008, 19:12
BMW 328ti 94'
MB GLK 14'
KIA XCeed 21'
manau viena kazkuria parduok ir nusipirk vienodas :wink:
StandartinėParašytas: 19 Sau 2008, 19:21
E39 525i
Ex
E36 320i
E34 525d 535i
na o jei pirktis nauja tai kuria ? :? kuris lesis geresnis ?
StandartinėParašytas: 19 Sau 2008, 19:35
Vilnius - Panevėžys
ex E36 320 M52 94'
E46 M47tuD20 03'
Bosh graziau ziurysi ;)
Pas mano pazystama yra ZKW, o pas mane BOSH, nezinau kodel, bet vidiniai stikliukai graziau atrodo ir nenesa i gelsvuma.
StandartinėParašytas: 19 Sau 2008, 21:29
Kaunas-Ariogala
ex E36 318i m40b18 92m.
ex E36 325 TDS. 95m.
ex E39 523i 00m.
ex mazda6 03m.
Volvo xc90 03 m.
arnoldas3001
arnoldas
manojoj E36 , dvi skirtingos lempos, viena bosh, kita net nzn , ir vienodai sviecia .... manau neskubek ju keist, nebent rasi kam vienos lempos prireiks, o jei pinigus mest lauk tai #-o . o del lempu pasirinkimo, pasilikciau BOSH :wink:
BMW - it isn't car, it's my life style
StandartinėParašytas: 30 Bal 2008, 10:02
tas ZKW yra fufeliai, buvau nusipirkes masina irgi su vienu BOCH kitu ZKW zibintu , kaip nekeista tech. apziura praejau su skirtingais, bet prie progos pakeiciau i BOSHa. Originalio eina tik BOSH arba HELLA , nors labai daznai pasitaiko ir Vokietijoj masinos su ZKW zibintais
StandartinėParašytas: 30 Bal 2008, 10:08
Henris rašė:
originalios yra BOSCH, ZKW, Hella. neklaidink zmoniu.
StandartinėParašytas: 30 Bal 2008, 10:12
Buvo:
E46 330d '04
E46 330d '02
E46 320d '00
E36 325tds '98
E46 330d '00
E36 328i '95
E36 320i '94
Henris rašė:
tas ZKW yra fufeliai... Originalio eina tik BOSH arba HELLA...
Geras pasakorius :D
Paziurim cia: http://bmwfans.info/original/E36/Cou/32 ... l-63_0267/
O siaip man grazesnes ZKW, nes tamsesnes :wink:
StandartinėParašytas: 30 Bal 2008, 10:46
EX: E30 324d M21 86'
EX: E36 318i M40 90'
EX: E36 325tds M51 99'
EX: E36 318is M42 95'
EX: E91 320d M47/T2 06'
EX: E39 530d M57 03'
EX: E46 323Ci M52 99'
E46 330Ci M54 01'
F25 x28i N20 17'
aš irgi už ZKW. Liašis sidesnis, aišktu tai dideles reikšmės neturi, nes esmė reflektoriuje, bet kažkaip gražiau žiūrisi. :)
Ir šiaip kiek USA forumuose teko skaitinėti, tai tie kurie nori susistatyt xenonus, siunčiasi europines originalias ZKW lempas. Ir nemažus pinigus už tai moka. :D
StandartinėParašytas: 01 Geg 2008, 13:41
E34 520i M50 91' M-Tech
edzhyx
Tavo reikalas, aš prijaučiu Bosch'ams, tai juos ir susidėjau. Toks retorinis klausimas, yra originalių baltų posūkių E36? Nusipirkau Depo papigiai, tikiuosi laikys :roll:
StandartinėParašytas: 06 Geg 2008, 23:44
Nissan Silvia S12'84
Opel Monza GSE'84
Mazda MX-6'93
Mazda 6'09
Jei kas nores keistis Bosch i ZKW - msg me ;) Irgi akys skirtingos :) Beje kas liecia posukius, tai siulau dar papildomai is vidaus juos pritvirtint, nes as sau pirkau ta taivanio gamybos ir per savaite jis man sugebejo iskristi :) Reiks velnias dar viena pirkt ir jau kokia plona vielute ar spyruokle "prisabachint" prie kebulo is variklio puses.
StandartinėParašytas: 07 Geg 2008, 09:24
pakeiciau 3 komplektus posukiu. reikejo keist tik del to, kad sulauzdavau fiksatoriu kur prie faros tvirtina posuki. o siaip viskas ten gerai su jais...
