Dabar yra 22 Bal 2026, 03:25
Naujos temos kūrimas Atsakyti į temą  [ 154 pranešimai(ų) ]  Eiti į 1, 2, 3, 4, 5 ... 11  Kitas
StandartinėParašytas: 27 Gru 2009, 16:55
Klaipeda
ex E30 320 1985m. BMWE46 2.0i 1999m
borka1973
Borisas
Pagaminimo metai:1999
Variklis:2.0i
Degalai:benzinas
Problema/klausimas:Sveiki kolegos.Problemele butu tokia:uzsidege ABS ir ASC lemputes, ryte pavaziavus truputi uzgeso,po kiek laiko uzsidege vel ABS ,ASC ,ir rankinio stabdzio lemputes ir dega pastoviai.Paieskoje nieko konkretaus neradau.Noreciau paklausti ar galiu vazineti su masina,nes kol kas nera galimybiu susitvarkyti.Gal yra kokiu minciu kaip isspresti sia problema.Ačiū uz atsakymus.
problema isspresta ,buvo numires kaires puses galinis ABS daviklis.Prie to pacio norejau pasakyti jei numires kairysis daviklis tai pradeda streikuoti spidometras ir ekonomaizeris. Visiems ačiū uz patarimus .Problema isspresta.
StandartinėParašytas: 27 Gru 2009, 16:57
Panevezys
E39 520 96'
andris0307
Urvinis
o tai ABS veikia normaliai?
StandartinėParašytas: 27 Gru 2009, 17:04
tai gal akumas mirstantis pas tave, tada būna tokios nesamonės, pasitikrink.
StandartinėParašytas: 27 Gru 2009, 17:15
Klaipeda
borka1973
Borisas
Akumuliatorius suka gerai.Neveikia nei ABS nei ASC.
E46 330xd. 02'
DSC, ABS, and BRAKE lights all illuminated?
This happens when the car has detected a fault and has disabled the DSC and ABS systems. If you recently drove on ice, a dynamometer, or on another very slippery surface, the car may just /think/ the system has malfunctioned. Driving a few miles on a regular surface should fix the problem.
Another fix is to slowly turn the steering wheel from completely left to completely right, then back again.
If you did not recently drive on ice and the wheel turning solution did not work, this is usually caused by either:
One of your wheel speed / ABS sensors failing (there's one on each wheel)
The DSC pressure sensor on the brake master cylinder is faulty
Your steering angle sensor has failed
Your battery needs replacement
Manau pades.
StandartinėParašytas: 27 Gru 2009, 17:20
Klaipeda
borka1973
Borisas
ačiū Donatas 20.Reikes po svenciu akumuliatoriu pasitikrint.Prie to pacio norejau paklausti ar ABS davikliai visi vienodi ar skiriasi priekiniai ir galiniai ?
StandartinėParašytas: 27 Gru 2009, 17:40
Bergen
ex E46 320d M47 98'
exE46 330d M57N 03'
exE87 118d N47D20A 08'
exE87 116i N45B16A 05'
E60 520d N47D20A 08'
azuolas003
priekis ir galas skiriasi
StandartinėParašytas: 27 Gru 2009, 17:44
Klaipeda
borka1973
Borisas
Kaip patikrinti akuma namu salygom ?
StandartinėParašytas: 27 Gru 2009, 17:45
Bergen
ex E46 320d M47 98'
exE46 330d M57N 03'
azuolas003
ir duodu kokia 80 procentu kad tai bus vienas is galiniu abs davikliu. nes pas mane kai neveikdavo priekinis abs daviklis, degdavo tik abs ir asc lemputes, o sia ziema sustreikavo galinis, nes nulauztas pats abs daviklis ir tin ant laidu kabo, tai dega rankinio, abs ir asc lempos.
StandartinėParašytas: 27 Gru 2009, 17:49
Klaipeda
borka1973
Borisas
Tai ar galiu vazineti su masina ,nebus blogiau ? Nes servizas kuriame pastoviai tvarkau atostogauja iki sausio 10.
StandartinėParašytas: 27 Gru 2009, 17:52
Bergen
ex E46 320d M47 98'
exE46 330d M57N 03'
azuolas003
nieko bloga neatsitiks, tik kad neveiks antipraslydimas ir abs
StandartinėParašytas: 27 Gru 2009, 17:58
Klaipeda
borka1973
Borisas
Ar diagnostika parodys kuris daviklis sugedes ? Pakeitus ABS davikli reikes klaidas trinti ?
StandartinėParašytas: 27 Gru 2009, 18:05
Bergen
ex E46 320d M47 98'
exE46 330d M57N 03'
azuolas003
rodys, o pakeitus davikli ir pravaziavus 100 metru lemputes uzges, o klaida liks, bet ji niekam netrukdys
StandartinėParašytas: 27 Gru 2009, 19:57
E46 330xd. 02'
Siaip del visa ko pabandyk ta bairi su vairo susukimu pilnai i kaire, o tada is leto i desine iki pat galo. Man padejo, o lemputes buvo uzsidege po akumo pakeitimo. iki tol viskas puikiai veike.
StandartinėParašytas: 27 Gru 2009, 20:17
Klaipeda
borka1973
Borisas
ačiū reikes ryt pabandyti su tuo vairu.Ryt parasysiu kaip sekesi.
