Dabar yra 05 Bir 2025, 10:40
StandartinėParašytas: 11 Vas 2007, 02:33
BMW motorcycle technical information
Slash 2 1955 to 1969
Super valuable /2 information at Bernd's site http://home.tiscalinet.de/strichzwei/Be ... /index.htm
See exploded views of your Bing carbs at http://www.bingcarburetor.com/bmw/bmw.html
Marc's step by step R69S restoration http://www.snafu.org/restore/ and very good too.
Info on the /2 electrics http://www.snafu.org/restore/uandm_bmw_v1.pdf generally good, but is missing some info.
To update your /2 ignition/generator system http://w6rec.com/duane/bmw/mz/mz.htm
Parts manuals from 1936-69 http://www.beemergarage.com/manuals.html
How to build a /2 BMW wheel http://agwalker.com/wheelbuilding.html
Some very good photos of various BMWs. http://www.bumpworks.com/BMW/index.html
Dar (kiek padrika info, bet ... info) http://home.jps.net/~snowbum/techindex.htm
Yep, dar: http://www.bynumonline.com/airheads/index.html
... http://www.tfmicrosystems.de/ ( http://www.tfmicrosystems.de/html/lima.html )
& more: http://www.geocities.com/MotorCity/Spee ... crank.html
more: http://www.geocities.com/MotorCity/Spee ... index.html
StandartinėParašytas: 11 Vas 2007, 02:56
Ir dar labai geras patarimas (su netiesiogine google reklama) :)
One should be able to learn almost anything about a BMW by researching enough links, To search for BMW info, I suggest using google. Go to http://google.com and type in "bmw motorcycle" first and then the words that may apply to your interest, such as "timing" "fairing" or "wheel bearings" and you will go to some site that can give you info. You might be surprised at what you find.
