Dabar yra 29 Geg 2024, 10:32
StandartinėParašytas: 27 Lap 2009, 22:07
ex E36 320 cupe M50 94'
ex E39 530 D universal 01'
ex F 650 GS/M DAKAR 04'
ex F 650 GS/M 05'
ex Z3 roadster M54 02
G 650 XChallenge 08'
E91 LCI 320D 09'
Persona non grata
toli eiti tektu, visus 150 km :)
reiks elektroniniu jiems parasyti
Pasaulis yra ne toks, koki mes ji isivaizduojame, jis yra toks koks yra....
StandartinėParašytas: 02 Gru 2009, 10:12
ex F 650 GS/M 05'
E91 LCI 320D 09'
Persona non grata
Nieko, netraso, formuojasi ne kokia nuomone apie sia kontora "krastaauto"
StandartinėParašytas: 04 Gru 2009, 10:38
ex F 650 GS/M 05'
E91 LCI 320D 09'
Persona non grata
Oficialiai atsiprasau Krasta auto, nes ivyko bugas su pastais ir negavau atsakymo is ju, nors issiunte.
StandartinėParašytas: 04 Gru 2009, 13:37
Ka suzinojai ?
StandartinėParašytas: 04 Gru 2009, 14:14
ex F 650 GS/M 05'
E91 LCI 320D 09'
Persona non grata
trumpai aiskiai, kad sitas tepalas tinka tiek automobiliams tiek daugeliui motociklu
StandartinėParašytas: 04 Gru 2009, 20:26
Choosing an Oil for Your Motorcycle
There are a few special problem areas for motorcycle oil. Most motorcycles have wet clutches, which means the motor oil runs through the clutch. If the motor oil has too much molybdenum in it, there are fears that the clutch can start slipping. No one I know has ever actually had this happen to them, but the warnings are all over your owners' manual and the oil companies' web pages. On the back of all certified oil cans is a circular stamp with the certification. Avoid oils that say "energy conserving" in the bottom half of the donut. These oils contain friction modifier additives that could cause clutch slipping over time. Essentially all 0w-20, 5w-30 and 10w-30 oils are energy conserving, and should not be used in your motorcycle.
Most motorcycles run the engine oil through the transmission, and the transmission gears are very hard on the oil's VII package. This means that over a couple thousand miles, the oil's viscosity can break down. Standard car oils are only good for typically 1500 miles before they've lost about half of their viscosity. Remember, 10w-40 oils contain a lot of VIIs which tend to shear in your transmission, so I believe 10w-40 oils should be avoided. You can't use 10w-30 because of the friction modifiers. This doesn't leave much. Commercial 15w-40 oils are a good choice, because they have relatively few VIIs which are the more expensive shear-stable sort. Synthetics typically don't contain much of a VII package, so shear is not as big an issue with them.
Some people use their motorcycles only sporadically. This means the oil can all drain completely into the sump, leaving no protective film on the bearings. The first start after a long period of non-use can be particularly hard on an engine. Film strength is very important if you're a sporadic rider.
There are several key advantages to using Synthetic Oils:
Synthetic oils have a higher viscosity index than mineral base oils. Synthetics have better resistance to thinning at high temperatures and thickening at low temperatures. Since synthetics have little or no VIIs, synthetics last longer in service without radical changes in viscosity.
Synthetics have a much higher film strength than petroleum oils, so it takes a lot longer for the oil to drain completely off your bearings and into your sump.
Diester synthetics are polar molecules with solvent properties which dissolve residues and combustion byproducts.
StandartinėParašytas: 07 Gru 2009, 10:35
ex F 650 GS/M 05'
E91 LCI 320D 09'
Persona non grata
is kur cia info?
StandartinėParašytas: 07 Gru 2009, 18:23
nepamenu :)
StandartinėParašytas: 08 Gru 2009, 10:38
ex F 650 GS/M 05'
E91 LCI 320D 09'
Persona non grata
Tai kiek leidzia kuklios anglu kalbos zinios, tai tepalai turintis galia taupanciu komponentu netinkami mocams.
Kas tas yr VIIs ? :)
Ir kiek supratau is sio straipsnio 15-40 yra geris :)
StandartinėParašytas: 09 Gru 2009, 13:12
VII = viscosity index improvers
Viki radau.
